#3 'Apple' Soil Humidity Sensor
Published
Introduction: #3 'Apple' Soil Humidity Sensor
1, Apple earphone box
2, Arduino pro mini
3, Soil humidity sensor
4, 74HC595 shifter
5, 2 digit LED (common negative pole)
5, 330 ohm resistance X 2
6, some wires
Step 1: Cut the Earphone Box
Cut the inner of the earphone box, and make a slit fit for soil sensor's installation.
Step 2: Circuit Design
Step 3: Solder All Things Together
It is easy to make mistake when solder circuit.
So be careful and check.
Step 4: Install Electrical Parts Into 'Apple'
Step 5: Start to Work
Connect to 5V DC power, it begin to work.
LED shows 0~99% of soil humidity.
Arduino pro mini input volt range is 5~12V, you can use 2 X 3.7V Li-Po battery to make it as a portable measurement sensor.
Step 6: Arduino Codes
//Soil humidity sensor by TL.Zhang
//Publish on www.instructables.com
//user name:bluestar179
//2015.10.30
byte data;
int humidity;
int humidity_A = 1;
int humidity_B = 1;
int DATApin = 9;
int LATCHpin = 8;
int CLOCKpin = 7;
int SELECTpin_A = 6;
int SELECTpin_B = 5;
int SENSORpin = A0;
byte digitSeg[10] = {
B11101111 , // 0
B01000001 , // 1
B11011110 , // 2
B11011011 , // 3
B01110011 , // 4
B10111011 , // 5
B10111111 , // 6
B11000001 , // 7
B11111111 , // 8
B11111011 }; // 9
void setup() {
//Serial.begin(9600);
pinMode(DATApin,OUTPUT);
pinMode(CLOCKpin,OUTPUT);
pinMode(LATCHpin,OUTPUT);
pinMode(SELECTpin_A,OUTPUT);
pinMode(SELECTpin_B,OUTPUT);
pinMode(SENSORpin,INPUT); }
void loop() {
humidity = 109-analogRead(SENSORpin)/10;
//anlog singal is about 80(in water) to 1000(in air), change anlog singal from 0%(in air)~99%(in water)
if (humidity < 8)
humidity = 0;
if (humidity > 99)
humidity = 99;
humidity_A = humidity/10; //get Ten digit
humidity_B = humidity%10; //get Single digit
//Serial.print("humidity=");
//Serial.println(humidity);
for(int i=0; i<100; i++){
//100 means get humidity singal 2s/time=2*delay*100
//send Ten digit to LED
digitalWrite(LATCHpin,LOW);
data = digitSeg[humidity_A];
shiftOut(DATApin,CLOCKpin,MSBFIRST,data);
digitalWrite(LATCHpin,HIGH);
digitalWrite(SELECTpin_A,LOW);
digitalWrite(SELECTpin_B,HIGH);
delay(10);
//send Single digit to LED
data = digitSeg[humidity_B];
digitalWrite(SELECTpin_A,HIGH);
digitalWrite(SELECTpin_B,LOW);
delay(10);
//shiftOut function tutorial see https://www.arduino.cc/en/tutorial/ShiftOut
    • Creative Misuse Contest
    • Clocks Contest
      Clocks Contest
    • Water Contest
      Water Contest
