Step 4: Making the 1st and 2nd layers
This step is hard to explain in words. You will need 30+30 of the folded pieces for the first two rows. 30 pieces for the first row and 30 pieces for the second row for a total of 60. Take a piece and stick one of the flaps into the fold. Do the same with the other side. you will need to do this for all 30 pieces and then join the pieces together to make a circle. The triangles should be alternating front, back, front, etc. They should also be facing up, then side, then up, etc. You are basically inserting "leg" to "mouth"
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
