In honor of all my good friends still over in Japan I've decided to create an Instructable for a $3 Emergency Solar Radio.  It's a great thing in case of tsunami, nuclear melt down, or zombie invasion.  Plus it's really cute when put into an Altoids tin.
My plan is to send this as a (slightly) joke birthday gift to a good friend of mine living in California, who just so happens to be freaking out about possible nuclear clouds.  This will also be really nice for her when she starts going camping again this summer.
The design is very simple and only takes about 45 minutes to put together, less if you know what you're doing.
If you'd rather not make one yourself, I'll probably be throwing up a couple completed ones as well as most of the parts over at my website BrownDogGadgets.com.
Step 1: What you need
I bought all the supplies I needed from my local $1 Store.  (If in Japan, a 100 Yen store.)
To buy:
1x FM Radio
2x Solar Garden Light
1x Diode ($1 for 100 of them online, or take one out of any random junk pile)
If your local $1 Store isn't as cool as mine, you can probably find these things locally, online (like at my website BrownDogGadgets.com), or from a trash bin.
Tools:
Soldering Iron
Drill
Wire
Wire Strippers
Googles
Tape
Optional:
Altoids Tin
Hot Glue
Mini Speakers ($1 Store, or take apart old headphones)
Support Me By Buying Some Parts...
If you can't find solar cells or cheap AAA batteries, I have quite a few on my website BrownDogGadgets.com.  The same solar cells I use to make my Solar Cockroach would work great for this project.  You could also slap on a bigger, more powerful cell onto the outside of the tin like these nice 4.5 volt cells.
I also some AAA battery holders and very cheap AAA batteries for sale that have a much higher capacity than the ones you'd find in your average solar light.
awesomeskier says: Mar 30, 2013. 2:43 PM
What diode do I use?
scottishmonster says: Jan 13, 2013. 1:29 AM
i suggest a schematic diagram for the project. please to make things simple
ladiesmanjoe97 says: Dec 30, 2012. 7:31 PM
Whatat does the diode do in the circuit? Just curious
Orkekum says: Dec 23, 2012. 10:26 AM
awesome idea and well written, i can buy cheap radio with a scan button and a return one
JoshuaZimmerman (author) says: Jun 19, 2011. 1:41 PM
Just because I'm a teacher doesn't mean that I'm not human.
With feelings to be hurt...
Sniff...
Orkekum in reply to JoshuaZimmermanDec 23, 2012. 10:22 AM
teachers are awesome c:
deanes says: Nov 12, 2012. 8:45 AM
Altoid tins are neat, but maybe an easier more practical project would be to just add the charging panels directly to the radio case? Or, maybe the panels glued to a plastic pocket-shaped sheet and connected by a sturdy wire to the radio battery compartment. Then you would have a solar charging case for the radio.
JoshuaZimmerman (author) in reply to deanesNov 13, 2012. 8:43 PM
Probably, but this is rather bare bones. Plus cute. You gotta factor in the cute aspect.
DAND says: May 8, 2011. 1:51 PM
What type of diode did you use?
static in reply to DANDNov 11, 2012. 4:11 PM
 The current carrying capability, the voltage rating and the voltage drop across the diode are considerations. Too much current can harm the diode, too much over voltage drop, the batteries may not fully charge. Nominal figures; for the silicon diode used here is .7 V, for the Schottky diode it's .2 V. In most solar application the Schottky is preferred, but one can't walk into radio shack and buy one. In low powered projects like this, it's easier to add an extra salvage solar cell, and used the more readily available silicone diode. No precision is required on the voltage rating here as long as it's higher than the battery voltage, the voltage rating is important if the diode will see a reverse bias as part as normal desired operation.
JoshuaZimmerman (author) in reply to DANDMay 9, 2011. 6:16 AM
1N914. Very common. You can find them everywhere.
earm99 in reply to JoshuaZimmermanJun 26, 2011. 8:49 PM
Thanks for the great instructables!
quick question
Are there any differences if you use a 1n914, a 1n4005 or a 1n5819?
JoshuaZimmerman (author) in reply to earm99Jun 26, 2011. 10:32 PM
1N914 us just really really common and has a low voltage drop. It's very handy for low voltage low current systems like in this one.
Google the other diodes and check the voltage drop. They probably would work fine for this kind of setup.
Subo69 says: Jul 12, 2012. 3:47 PM
if you were to use capacitors instead, which one would you use?
JoshuaZimmerman (author) in reply to Subo69Jul 12, 2012. 4:10 PM
Well you'd want some super capacitors. Ones that have 1F or more of power at around 3V.
Actually the best approach would be to get a couple of 1F 5V super caps and hook them up in Parallel. (5V so that you don't overcharge the caps, and can then use a 4V or 4.5V solar cell with the project.)
But you'd need several of them to be on the safe side. Really 3 or 4 if you want to use the radio out of the sun.
static in reply to JoshuaZimmermanNov 11, 2012. 3:00 PM
This reply is directed more to those that will read the comment made by the author than it is to the author. As science teacher none of the following shouldn't be new to him. F Farad http://en.wikipedia.org/wiki/Farad is not a unit of power.  A capacitor can't be overcharged, but is susceptible to damage from over voltage.  Following the author's suggestions here  the capacitors wouldn't see a voltage over their rating. In my experience, there will be those who would read this and think they could wire lower voltage capacitors in parallel and they would be safe too hook up to a higher voltage source. However wiring the in series  can allow them to be used with a higher voltage source, but the total capacitance will be reduced.  Knowing how capacitors wired in parallel or series behave allows you make use of what you have in the junk box or otherwise can attain readily to come up with what you need.  For more details read http://en.wikipedia.org/wiki/Farad .  Given the low current provided by the suggested salvage solar cells, I'd suggest doing the initial charge of a high capacitance bank from other power source. After that initial charge the solar cells should able to restore the charge in  available time of sunshine.
static says: Nov 11, 2012. 1:08 PM
Good instructable, but for my kit I have a AM/FM pocket radio that I bought from Radio shack for not much more than the cost here. Use 2 AA batteries, while I hive never tried rechargeable batteries I assume so the solar power should work.  At lower volume levels Alkaline batteries last well, so I'd take extra batteries. My guess is the  plastic radio case doesn't weigh much more than the tin is is more durable. Everyone seems to ignore AM, when AM will be received almost anywhere. Good tools for making holes in light weight metal are a hand metal punch http://http://www.amazon.com/Neiko-Power-Punch-Sheet-Metal/dp/B0002T87CW and a tapered reamer http://www.amazon.com/Empire-Level-27770-T-Handled-Tapered/dp/B001DZE5FW/ref=sr_1_1?s=hi&ie=UTF8&qid=1352666745&sr=1-1&keywords=tapered+reamer .  Links used for illustration purposes so shop around. The punches may cost less  from vendors serving those in the auto DIY crowd looking for bargains.
zinner342 says: Oct 9, 2012. 2:04 AM
Hi Joshua,
I really like your solar powered radio and I am probably going to use it for a school project. But I am confused? How does it all work? My school says that you can use solar power, but is this radio actually using solar power or is it using batteries? When the sun shines on the solar cells, what happens? Does it charge the batteries or what? SORRY, I KNOW I'M ASKING TOO MANY QUESTIONS :P
Thanks,
~ a different joshua ~
:P
ivanjacob in reply to zinner342Nov 10, 2012. 11:34 PM
the solar cells charge the batterys
aaronXtreme says: Aug 10, 2012. 4:44 PM
hey I have a biz kind of like what you do and I have been looking for a place to create one your website looks great and I was wondering what site you made yours on?
Ghosthost5468 says: Jul 4, 2012. 7:08 PM
Hey!This is a great Instructable and I have been planning to make one one these
but i got to know,how many volts do you use on your soldering iron because
they got a 25V,30V,40V,50V and 60V.So what do you suggest I use for this project
and your solar powered Altoids USB charger?
JoshuaZimmerman (author) in reply to Ghosthost5468Jul 7, 2012. 3:19 PM
I have no idea. My soldering iron isn't fancy enough to display "volts" used. It just has a temperature wheel with color coating.
Ghosthost5468 in reply to JoshuaZimmermanJul 8, 2012. 11:02 PM
Thanks,no sweat,I learnt a little bit about soldering so just do what you do!
Ghosthost5468 says: Jul 4, 2012. 7:30 PM
Also,I'm on the cheap here cause I'm in Beijing Plus I'm a kid but i managed to fint the exact same radio,so at least I'll be able to complete some of it.
Felixninja says: Jun 27, 2012. 12:50 AM
Hey Joshua, I saw the exact same radio in a local dollars and sense store, but it says do noy use rechargeable batteries, have you had any problems with the 1st radio?
JoshuaZimmerman (author) in reply to FelixninjaJul 2, 2012. 7:08 PM
I've had no problems. The issue is that regular AAAs give you 1.5V of power (so with 2 of them you get 3V) BUT rechargeables only give you 1.2V of power (so with 2 of them you get 2.4V).
As long as your project doesn't involve a motor or need a super specific voltage (for some reason) this really shouldn't be an issue. Yes, correct voltage is important, but for super simple little projects like the radio you're fine.
If you're really really really worried about voltage issues just wire up a third AAA battery to give you 3.6V and then limit it with a resistor so you get 3V inside the circuit (it may be fine with 3.6V anyways).
Doctor-X17 says: Apr 19, 2012. 7:03 AM
I like this project. Both versions look good, but you might be able to use speakers as you planned for the first version if you included an audio amplifier circuit. I'm not sure how small one could be made, though, or if it's feasible in terms of power consumption, but it might be a challenge for you to step up to! But internal speakers or not, this is a good Instructable. Keep up the good work :D
Also, anything in preparation for the Zombie Apocalypse is good.
JoshuaZimmerman (author) in reply to Doctor-X17Jun 9, 2012. 10:15 AM
Ooooo good idea! Headphones are alright, but speakers could get everyone rocking.
Then again, you could just build a more powerful solar setup and use a more powerful radio. It wouldn't be Altoids sized, but it would be more rocking.
Zombie killing rockin.
DoctorDv says: Jun 9, 2012. 7:10 AM
I made one and I was wondering if you know where the antennae is so I could make it bigger and make the sound clearer. Thanks!
-Doctordv
JoshuaZimmerman (author) in reply to DoctorDvJun 9, 2012. 10:13 AM
In these simple FM radios the antennae could be anywhere. It depends on what type of radio you took apart. I wish I could help you out on that one.
dasimpson1981 says: Apr 14, 2012. 5:04 PM
you just need to make a altoids hand crank for the time you may not have sun lol or wind turbine in a altoids tin pmsl
sanyo8088 says: Nov 4, 2011. 12:43 AM
cool portable fm radio
nafaa says: Oct 26, 2011. 11:31 AM
waw , that's cool.
green_emi says: Sep 27, 2011. 3:35 PM
Great little device... can't wait see what you'll put in an Altoid case next!
Haven't see any similar kind of case here in Ireland but I'll be on the lookout.
Thanks!
tgray1 says: Jun 19, 2011. 10:05 AM
You're a teacher, so I know you misspelled "knob" just to see if your students are paying attention... right?
srayner371 says: Jun 9, 2011. 5:07 PM
I am just getting into this and am becoming addicted. I have ordered some kits off your website but was wondering for one thing what is the best gauge of wire to buy first to use for these projects?
JoshuaZimmerman (author) in reply to srayner371Jun 11, 2011. 9:28 AM
I like 22 gage stranded. That seems to be a good size to work with.
Kirbsome! says: Apr 23, 2011. 1:02 PM
Quick tip:
When buying solar powered lights for this, look for blue solar panels.
They are usually higher quality than the dark brown ones.
JoshuaZimmerman (author) in reply to Kirbsome!Apr 23, 2011. 11:42 PM
Very true. Those CIS are dark brown and very high quality...
icej75 says: Apr 17, 2011. 7:57 PM
When drilling thin material i have found that by placing a peice of wood behind it, you get a good "base" for drilling and reduce the drill flare on the inside.
JoshuaZimmerman (author) in reply to icej75Apr 17, 2011. 9:35 PM
Me too! Thats a great tip.
SinAmos says: Mar 23, 2011. 6:34 PM
Why is this funny? Because I just took apart some solar lights that stopped charging those 600 mah batteries. I checked the ability of them to produce power with my power meter, which they were still able to do, but at a lesser rate. Then, the two solar lamps you have in your instructable actually have turned up at the 99 cent store for a buck a piece. Going back to what someone else mentioned, the option to turn off the lamps while still letting them charge the batteries is possible. That way, they just charge the batteries, which you remove and put into your battery. Combining them is probably more cumbersome.
JoshuaZimmerman (author) in reply to SinAmosMar 31, 2011. 9:26 AM
Its very easy to set up a simple circuit using a transistor and a resistor to make your LEDs turn off in sunlight. Most solar lights use that same system internally. Most solar lights use one AA or AAA battery and a solar cell greater than 3.5 volts. The most common reason they fail is because the battery wears out. Replacing the battery is, usually, extreamly easy. I've done that for my parents several times. Don't throw out that light, just replace the battery. If you need batteries I have heaps of cheap ones that I buy for my website. They're the same ones I used to replace the batteries in my parent's solar light. Give my website a try and get some batteries. BrownDogGadgets.com
macrumpton says: Mar 23, 2011. 1:11 PM
This is a cool project, but rather than pulling apart the radio to make a radio, I wonder if it would not make more sense to just make a solar battery charger so you could use the charged batteries in anything that needs them.
JoshuaZimmerman (author) in reply to macrumptonMar 23, 2011. 1:23 PM
You could. Or you could just solder the solar panels onto the oiginal FM Radio body, but where would the fun be in that?
The goal was to have an Emergency Radio in a compact case. Something to throw into your "Emergency" bag, First Aid kit, or to take camping.
Also it's just a bit more fun to build it all into an Altoids tin. If you're cafeful you can build in headphones so that the entire project is self contained. I was able to fit in headphone during my second try, but I used smaller and more efficient solar panels. That jumped the price up to about $6 for the entire thing.
Really for between $3-6 it's not a bad project, and is much cheaper than buying a off the shelf emergency radio.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
