$3 Emergency Solar Radio by JoshuaZimmerman
Featured
Step 12: Version 2.0
So I gave building one of these a second try and it worked out a bit better.  This version is just like the old version, except on steroids and a bit more expensive.
I used another $1 Store Radio as well as managed to fit in some $1 headphones.  Instead of using the $1 Store solar lights I instead used three 1.5 volt 50 ma solar cells which are smaller and more powerful.  I also used some higher capacity AAA batteries I had.
The total cost of this one is about $6-7.  Twice as much as the original one, but still much cheaper than buying a store bought solar radio and far more cute in this Altoids Tin.
Oddly I now have a complete solar Altoids kit setup in my room.  Solar Radio, Solar Flashlight, Solar USB Charger... In the event of a massive power outage (or zombie invasion) I think I'm set.
deanes says: Nov 12, 2012. 8:45 AM
Altoid tins are neat, but maybe an easier more practical project would be to just add the charging panels directly to the radio case? Or, maybe the panels glued to a plastic pocket-shaped sheet and connected by a sturdy wire to the radio battery compartment. Then you would have a solar charging case for the radio.
JoshuaZimmerman (author) says: Nov 13, 2012. 8:43 PM
Probably, but this is rather bare bones. Plus cute. You gotta factor in the cute aspect.
Doctor-X17 says: Apr 19, 2012. 7:03 AM
I like this project. Both versions look good, but you might be able to use speakers as you planned for the first version if you included an audio amplifier circuit. I'm not sure how small one could be made, though, or if it's feasible in terms of power consumption, but it might be a challenge for you to step up to! But internal speakers or not, this is a good Instructable. Keep up the good work :D
Also, anything in preparation for the Zombie Apocalypse is good.
JoshuaZimmerman (author) says: Jun 9, 2012. 10:15 AM
Ooooo good idea! Headphones are alright, but speakers could get everyone rocking.
Then again, you could just build a more powerful solar setup and use a more powerful radio. It wouldn't be Altoids sized, but it would be more rocking.
Zombie killing rockin.
dasimpson1981 says: Apr 14, 2012. 5:04 PM
you just need to make a altoids hand crank for the time you may not have sun lol or wind turbine in a altoids tin pmsl
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
