The plug you will need to purchase is a TRRS. I purchased mine at (just copy and paste the link):
http://www.showmecables.com/product/3-5mm-Plug-TRRS-Connector-Metal.aspx
Here is the order description:
Part Number: 945
Description: 4 CONDUCTOR 3.5 mm PLUG WITH METAL HOUSING
The part costs $4.15 + shipping and handling. (Price may vary)
If you have any questions feel free to comment below. GOOD LUCK!!!
Thanks.
I have wired, behind the neck, stereo headphones with mic that I love for my phone, but had shorted right at the connector point. I have looked online and at every place that sells these types of things that I happen across and can only find the ear buds (they are too unstable) type. The bluetooth version is just not as reliable and not as stable for use when active!
Thanks so much!!
However the red-green-white twisted cable should be seperated and only the white attached to the big bottom plate.
The red and green cables that were twisted around the white should connect together with the copper to the ground on the connector sticking out to the side.
I learned this by cutting apart and disecting the old plug and by connecting this way everything workes.
