Convertible Wooden Fidget Spinner | Shuriken / Slingshot / Screwdriver
Published
Introduction: Convertible Wooden Fidget Spinner | Shuriken / Slingshot / Screwdriver
About: Hello there! Thanks for stopping by! I'm Elias and I'm addicted to Making, Building and Creating any kind of things, producing free DIY videos and showing you How it's done, step by step! Here you can see s...
In this instructable you will see how I built a 3-in-one fidget spinner made out of wood, some bit holders and a bearing.
Step 1:
Firstly, I cut the piece of wood in the dimensions I wanted.
Step 2:
After I designed the shape of the fidget spinner on the wood, I started cutting it with a jigsaw.
Step 3:
Then I sanded it, very well in order to give it the desired shape.
Step 4:
Now, with a 3mm drill bit, I drilled the five edges, in the middle, on the top side of the wood.
Step 5:
After that, I cut the bit holders at the right length and measured their thickness.
Step 6:
I drilled the holes with a 10mm drill bit and then with a router I started rounding all the edges.
Step 7:
Then, I sanded it again very well and gave its final shape.
Step 8:
Now, I removed the metal shields from the bearing and cleaned it with WD-40 in order to spin faster.
Step 9:
I measured the diameter of the bearing and I drilled a 22mm hole.
Step 10:
And I placed the bearing and the bit holders together with the piece of wood in order to see that everything fits right.
Step 11:
And I started placing the bit holders into the holes, one by one, using super glue.
Step 12:
After the glue dried up, I drilled every bit holder with the wood separately, placing a screw between them, so that the bit holders can’t be moved when I use the fidget spinner as a multi bit screwdriver.
Step 13:
I cut the screws with a hacksaw, sanded it again very well and the Fidget Spinner is ready for use!
Step 14:
Multi-Bit Screwdriver
Step 15:
Slingshot
Step 16:
Shuriken
Step 17:
Thanks for reading! I hope you liked it!
https://www.youtube.com/subscription_center?add_us...
    • Planter Challenge
      Planter Challenge
    • Woodworking Contest
      Woodworking Contest
    • Pets Challenge
      Pets Challenge
    5 Comments
    add you design to https://www.instructables.com/contest/fidgetspinner
    Hello there! I tried it but they did not accept it.
    Thank you for your interest!
    Best wishes!
    You will have to make 3d model. You can use tinkercad. You will need to follow few ground rules, you can start by using https://www.tinkercad.com/things/gYbQBBG83np
    Thank you very much! I'm really happy that you liked it!
    Stay tuned for more! Best wishes!
