3 Simple, Yet Cool DIY Projects (P2)
Published
Introduction: 3 Simple, Yet Cool DIY Projects (P2)
About: Innovative Projects, Diy's, Life Hacks
In this Instructable, we look at 3 simple DIY projects
We will make something from a hollow brick, domino's and a CD cake box.
This is a second part of the Instructable "3 Simple, Yet Cool DIY Projects"
If you are Interested in the video version of this Instructable and the embedded video does not appear on your mobile device, here is an alternative link
Step 1: Toothbrush Holder or a Desk Organizer
I took a hollow brick that I found on the street and I draw a line where I want to cut it.
I cut the brick from all sides with an angle grinder.
Then I broke it in half by applying some pressure.
I also cleaned up the rough edges with an angle grinder.
Step 2: Toothbrush Holder or a Desk Organizer
I glued a piece of foam to close the bottom and painted the brick red.
We have made a toothbrush holder or a desk organizer.
Step 3: Paper Towel Holder
I had CD cake box lying around.
I cut a piece of ABS pipe and put a cap on one end.
Step 4: Paper Towel Holder
I put a few CD's on the spindle before sliding on the pipe.
Pipe was a perfect fit. No glue was needed.
We have made a paper towel holder.
Step 5: Domino's Flash Drive
I had a flash drive without the case.
If you don't have one, you can take apart an ugly flash drive.
You will need 3 domino's tiles.
Make 3 cuts in one of the tiles to remove the center.
I used a wooden domino's tile. If you have plastic domino's, you might need to use a rotary tool to cut it.
Step 6: Domino's Flash Drive
Glue the piece with a cut on top of another tile.
Step 7: Domino's Flash Drive
Cover the flash drive with the glue and put it inside of the domino's tile.
Step 8: Domino's Flash Drive
Close the flash drive with another tile.
We have made a custom domino's flash drive.
    • Stick It! Contest
      Stick It! Contest
    • Creative Misuse Contest
    • Water Contest
      Water Contest
    6 Discussions
    Nice! I would have painted the desk organizer green/orange/black I think it would look the best on my desk, But as a toothbrush holder, Red looks pretty good
    These are the continuation of signs of a great mind.
