Introduction: 3-Step Wire Control
Note: This instructable is supposed to be ridiculously simple please do not give low ratings because of this
This is my system for controlling wire clutter for hot glue guns, soldering irons, etc.
In this case I will be using a usb cable (because it was the first cable I could find).
Step 1: Collect Materials
All the materials you will need are:
1 rubber band
1 messy cable
Thats it!
Step 2: Wrap Cable
Wrap the cable into figure 8's
how many you need depends on the cable you are using
Step 3: Wrap Rubber Band Around Cable
Take the rubber band and slip it around the cable then make a figure 8 and wrap it around again
how many times you will need to do this depends on what wire you are using
(hard to explain just see pictures)
Step 4: Finished
These are very loose instructions so the method can be changed to fit any need.
Hope you have found this useful! Please comment, rate, and suggest!
