3 Things You Can Make From Aerosol Cans
51,187
175
31
Posted
Introduction: 3 Things You Can Make From Aerosol Cans
If you have empty aerosol cans lying around, don't throw them away just yet.
They can be used to make a few useful things.
In this Instructable, I demonstrate 3 ways you can upcycle empty aerosol spray cans.
If you are Interested in the video version of this Instructable and the embedded video does not appear on your mobile device, here is an alternative link
Step 1: Pulley
Before cutting open an aerosol can, make sure it's empty. It's a good idea to puncture a hole before cutting the can with tools that could create a spark.
Step 2: Pulley
I cut off the top from 2 cans. Cordless drill was used to spin the disk, so it's easier to sand it.
Step 3: Pulley
I removed spring, stem and the plastic that was holding them.
Step 4: Pulley
I glued both disks together and used bolt&nut as a clamp.
Step 5: Pulley
I made the hole bigger
Step 6: Pulley
I bent and "L" shape bracket into a "U" shape
Step 7: Pulley
I cut a bolt to size
Step 8: Pulley
I used 2 nuts to attach the bolt to the wheel.
I used acorn nuts for ends of the bolt.
To make sure nuts don't get loose, I applied some glue.
Step 9: Pulley
That's it!
Our light duty pulley is ready.
Step 10: Handle
I cut off top and the bottom from the can.
Step 11: Handle
I glued a nut to the top disk.
Step 12: Handle
Then I glued both disks together.
We have made a simple handle.
Step 13: Spinning Toy
I cut off top and the bottom from a can
Step 14: Spinning Toy
Then I glued the stem (stem from pulley's can) to one of the disks.
And last, I glued both disks together.
That's it!
We have made a simple spinning toy.
It can spin for more than 2 minutes.
    • Science of Cooking
      Science of Cooking
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    31 Comments
    Me encantó!!, Gracias por enseñarnos
    I love all of these. From practical to fun; all great ways to re-purpose one of the worst landfill offenders there is. I'm making that pulley ASAP. Thanks for sharing.
    I like this. How many times have I wanted a pulley and not had one, then when at the store, I forget again.
    I think the spinning top would have spun even longer if it had not hit the wood edge.
    Yes, it would.
    It wsa hard to make it spin without hitting the wood at some point.
    Man, where do you come up with these ideas? They are awesome. But i have never seen anyone cut a can with scissors. I normally use a hacksaw. But this helps me to see it "can" be done. Thanks for sharing your imagination.
    Ha, ha..Thanks :)
    I do have metal cutting scissors, but they don't cut too good.
