3 Things You Can Make From Syringes
Introduction: 3 Things You Can Make From Syringes
In this Instructable, we look at 3 things you can make from new syringes.
We will make a microphone stand, a syringe gun and a sausage cutter.
What's needed:
For the Mic Stand
  • Lid from a tin or the tin
  • Syringe
  • Hot Shoe Ball Head
  • 3 large size nuts
For the Syringe Gun
  • Syringe
  • Electrical tape
For the cutter
  • Syringe
  • Steel wire
Other things: Spray paint, hot glue, drill+drill bits, permanent marker
If you are Interested in the video version of this Instructable and the embedded video does not appear on your mobile device, here is an alternative link
Step 1: Adjustable Microphone Stand
I took a large syringe and cut off the bottom (or the top, depends how you look at it)
Then I sanded it.
Step 2: Adjustable Microphone Stand
I took a lid from a tin/box I had lying around and I drilled a hole in it.
Step 3: Adjustable Microphone Stand
I glued the syringe to the lid as well as few nuts to make the stand heavier.
Step 4: Adjustable Microphone Stand
After putting the plunger back into the tube, I painted the stand black.
Step 5: Adjustable Microphone Stand
I bought a cheap hot shoe ball head from eBay (around $2)
I glued it on top of the plunger.
That's it!
We have made an adjustable microphone stand.
Works great with my zoom H1 audio recorder.
Step 6: Syringe Gun
I put a spring onto the plunger and squeezed one of the ends ,so it would not slide off.
Step 7: Syringe Gun
I painted the syringe black
Step 8: Syringe Gun
I made flights for the needle with an electrical tape.
Then I closed the needle with hot glue.
Step 9: Syringe Gun
That's it!
Our syringe gun is ready!
Put on the needle, but not as tight as usual.
Press the plunger and the needle will shoot.
The spring will bring back the plunger to the start position.
As you probably already know, the needle is very sharp.
Treat this syringe gun with respect and stay safe.
Step 10: Vegetable&Sausage Cutter
I took a large syringe and cut off the bottom.
Then It was sanded.
Step 11: Vegetable&Sausage Cutter
I marked the points for drilling with a permanent marker and electrical tape.
Then I drilled 18 holes.
Step 12: Vegetable&Sausage Cutter
I looped a steel wire through the holes making a cutter/blade.
Step 13: Vegetable&Sausage Cutter
Our syringe cutter/slicer is ready.
Put in a sausage and press down the plunger.
If you ever need to chop a sausage for the salad, this way it will be much quicker.
I also tried to cut a carrot. It did work, but I had to press it down harder.
The steel wire I used was too thick. Thinner wire will do a better job.
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    • Pocket-Sized Contest
    And I thought it was a noodle maker...
    The easiest way I've ever seen to julienne a hot dog.
    ONLY way I've ever seen to julienne a hot dog! Who knew such a need existed? I had to read the whole Instructable to find out what that was. I thought it was modelling clay. Might be good for making wiener octopi.
    I had my eye on the octopi as well!
    If you push the hot down about 2/3 of the way in you'd have perfect tentacles. But then I got stumped on how the heck you'd remove it. Womp womp womp
    If a person REALLY needed a kitchen gadget purpose-designed for making hot-dog octopi, maybe it would be possible, instead of 'weaving' the same wire back and forth / in and around, to have the wires removable (like 2 intersecting combs) with a ring to lock them into position when in use, and then they could be pulled free of the partially cut 'dog'. This would not be strong enough to remain in place for cutting something like a carrot, however. Also someone who really needs a purpose-designed gadget for making wiener octopi also really needs something more important to think about. This would be a sit-com project (one to do while watching TV, taking no more than half an hour)
    What's more important than wiener octopi making gadgets is the subconscious thought process that goes on while watching sit-coms or pursuing more important things. The subconscious accounts for about 90% of the brain's activity were the real thinking, problem solving & "breakthroughs" come from. A half hour may not be enough so it might keep working into the next show and after you go to bed. Those sit-coms just give your brain time to "think on it's own". It's like telling the kids to watch cartoons "while mommy works".
    Four crossed sewing needles through evenly spaced holes would cut eight tentacles.
    A larger "syringe" from PVC pipe sized to process a whole baloney from the local deli could make a giant "mother of all" wiener octopi for the centerpiece.
    i see it now! Four pins/needles from one side and four from another, crossing each other and making 16 square. Plunge the dog thru half ways then remove the pins and free said weiner octopus by pushing is all the way thru. The pins would act like a magician's sword box. Thanks for the idea!
