3 Ways to Make Water Glow!
27,371
246
27
Published
Introduction: 3 Ways to Make Water Glow!
About: Hello, WorkshopWizard here! Have you ever asked yourself questions like: How does that work? Or how can I solve that? Join me as we explore the wonders of woodwork and the intriguing world of electronics. We...
Do you have a party to host soon? Stand out from the crowd at your next get together with these 3 super simple science tricks to make water glow!
For all of the following you will need a UV black light. These lights have lots of applications in the sfx and lighting industry, but are also great for your social gatherings. The following will not work without one. You can find many different types of UV black lights online from ones that simply fit into your original light fitting too standalone units that plug into the wall.
Some of the following science tricks can be quite messy so be certain to wear suitable clothes and protect your workspace. Also, some but not all of the following are edible. However be extremely careful not to consume the ones stated and if you use common sense, you'll be just fine.
Now let's make some awesome water and just glow with the flow (no pun intended)!
Step 1: Tonic Water
The first method to make water glow is as simple as getting hold of some standard tonic water. If you look at the ingredients on the bottle, you will see that it has an ingredient called quinine or quinine hydrochloride and this is the ingredient that makes the water glow under UV light.
Hold the bottle close to the UV light in a dark room and watch the water glow a pale blue colour!
Tip: experiment with different brands of tonic water as some may contain stronger concentrations of quinine resulting in a brighter and more vivid glow.
A great use for this trick (as tonic water is perfectly safe to consume) would be to fill your drinks with tonic water at your next party to give your guests a spooky surprise.
Step 2: Drain Tracing Dye
The second method to make water glow is using something called "drain tracing dye" which is used by plumbers to detect leaks and the flow of waste water. You should be able to get this from your local plumbing store or DIY store in a small jar. It's chemical name is fluoresceine.
When you open it up, it looks like a lot of small maroon colored grains.
Method:
Use either tweezers or your fingers (it is messy) to take a pinch of the grains and drop them into the water. Stir well.
Amazingly, this is all you need to dye over a liter of water (you can always add more for a more vivid colour).
This method will produce a vivid green glow when exposed to UV light.
Note: This method is NOT edible so do not consume the water. The dye can stain clothes and other objects it touches. Be careful to prevent it from spilling.
Step 3: Highlighter Pens
The final method to make water glow is possibly one of the easiest to reproduce however the process is quite messy so make sure you wear suitable clothes and protect your work area. This method also has many applications.
Method:
First experiment with different brands of highlighters as not all of them will work. You can see if it works by writing on a piece of paper and it should glow vividly under the UV light.
If it works, use a pair of needle nose pliers and pull the tip out from the body of the highlighter. Submerge the felt tip and the highlighter body in the water and let the ink and water blend together for a few minutes.
Expose the solution to UV black light and the water will glow!
If you intend to use more water, also use more highlighters to ensure the correct concentration of ink in the water.
This method will produce a colour the same as the highlighter colour that glows boldly under UV light.
There are lots of things you could do with this effect:
• Use the highlighters undiluted as they come out the packet and write funky messages in different colours.
• Pour the mixture into glass jars and turn them into vats of radioactive waste to display at your next Halloween party.
• Pour the mixture into a funky shaped clear container and display them as neon light pots at your next party.
• Pour a small amount of the mixture into a clear plastic straw with hot glue sealing one end and then seal the other end of the straw with hot glue and create DIY glow sticks.
Note: As before, this method is NOT edible so do not consume the water. The highlighters can stain clothes and other objects it touches. Be careful to prevent it from staining and use common sense.
Step 4: Results
So, that's three awesome ways to make water glow in funky colours.
Edit: There are actually a lot more common everyday items that glow under UV. Here's just a few:
  • Liquid Laundry Detergent.
  • Bank Notes.
  • Toothpaste.
  • Vitamin A and the B vitamins thiamine, niacin, and riboflavin.
  • Petroleum jelly i.e. Vaseline
If you know of any more items that glow in UV, please leave them in the comments.
It has to be said that the tonic water method is edible but the other two are not so please be responsible and use common sense.
If you have any problems or questions please don't hesitate to comment below.
I hope you enjoyed it. See you in the next instructable and as always - Happy Making!
    • Planter Challenge
      Planter Challenge
    • Casting Contest
      Casting Contest
    • Oil Contest
      Oil Contest
    27 Comments
    Wow thats awsome. I have never seen tonic water here in the us though. Any ideas where i might get some? I want to shock my guests!
    Hi,
    Thanks for your kind words. You can find tonic water at your local supermarket in the soft drinks section.
    Hope that helps,
    WorkshopWizard.
    I was down at Walmart eralyer and didnt see any. Could i use Lemonade as that's carbonated too?
    Hi,
    Unfortunately, lemonade wouldn't work as it isn't the carbonation that makes it glow. It is one of the flavourings in tonic water called quinine hydrochloride, therefore only tonic water will work.
    Hope that helps,
    WorkshopWizard.
    White cotton cloth glows under black light.
    Hey, recently this was posted. Add this to make four. Awesome!
    http://2a26fe15803eb331cbb88099b407aacc.proxysheep...
    Although there was a question regarding riboflavin and poisoning, Riboflavin is a "Water Soluble Vitamin" and your body just "Pees" it out. I didn't know you could buy flourisciene in a plumber's shop either. kul!
    Riboflavin needs no black light.
    It glows orange as soon it has left the bladder!
    When I was in high school my friend Randy and I activated a light stick, back then it was called Cyalume, and sprinkled it into the bowl of his dad's toilet (who was known to drink heavily.) The next morning he asked, "what the hell did you guys do to my toilet!?" Big fun, no deaths.
    Hi,
    I've not heard of riboflavin before. That's a good suggestion that seems as if it would work. Thanks for sharing!
    WorkshopWizard.
    Very cool trick and I can't wait to try it! I have three lava lamps so things like this fit right in with my decor.
    Great :-) Actually I did not now that quinine is fluorescent. But did you now that it is/was used to cure malaria?
    Hi,
    Thank you. I didn't know that quinine was used to cure malaria. That's an interesting fact, thanks for sharing!
    WorkshopWizard.
    I didn't know that either. some more information for my sister. I know a lot of pointless, and some not so pointless ,facts, mostly about manga. my username is my favourite Deadman Wonderland character. it's not bad to read. Kengamine is the leader of Scarchain, a group of people who are quite good friends, until chapters Cloudy After Being Sunny and Salty Cookies
    "tonic" = medicine
    They put gin in to make it taste nice
    Tonic is sparkling water, sugar and a bit of quinine. But adding gin makes it taste even better :-)
    I drink it without adding anything. stops me sleeping during the day so I can stay alert in school, just wish I drank some this morning, I feel so tired
    I don't know that quinine was ever a "cure" for malaria but a control. Just as it is quite helpful with restless let syndrome as well. My entire family suffers from restless let so we keep lots of tonic water on hand. Less expensive than the drugs out there and doesn't require paying a doctor for a visit every time it flares.....like you can get into a doctor at night anyway. LOVE my tonic water......I just didn't know it glowed under a black light.
    Now I don't know. No, I don't know anything right now.
    wow, I saw someone use the highlighter trick at mum's friends party. problem was, some of them got drunk and well, they tried to drink it, but instead managed to tip it all over the floor. to ages to clean up from a carpet. I need to get some tonic water, it's really nice to drink.
