3 Ways to Enable Administrator Account in Windows 7
842,607
53
33
Posted
Introduction: 3 Ways to Enable Administrator Account in Windows 7
In this instructable i will show you guys how one can enable Administrator Account in Windows 7
The administrator account is a hidden, disabled and built-in account with Windows 7/Vista/xp. But a user can enable this account for some special actions. Such as troubleshooting, installing harmful software or some special networking tasks. By default, most of the user accounts are a part/member of the Administrator account. Others are standard accounts without being any part of an administrator account.
Windows disabled this account to prevent malicious programs and harmful activities on the system. So any special task of system needs administrative privilege and the annoying UAC (User Account Control) bar will pop up for the users, except the administrator account.
This instructable will show you how to enable Administrator account in three easy ways. Choose only one method from below to activate administrator account.
Step 1: Method #1. Using Command Prompt:
Search cmd.exe in start menu and run cmd.exe as administrator.
To enable Administrator account Type: net user administrator /active:yes
Hit enter and the command should execute successfully.Command line to disable this account: net user administrator /active:no
Step 2: Method # 2. From Local Users and Groups
Go to control panel navigate to Administrative tools and computer management.
Expand the Local users and Groups arrow and select Users. Then, From the right pane, double-click on the Administrator.
Un-check the "Account is disable" and it should be look like below.
OK it and your settings will be saved.
From here you can also disable the Administrator or other account.
Step 3: Method #3. From Local Security Policy
Type secpol.msc in start menu and run it as administrator.
From this Local Security Policies, expand the security options under the Local Policies.
Find "Account: Administrator account status" from the right pane.
Open the "Account: Administrator account status" and choose Enabled to enable it.
You can also disable it from here.
After completing any of above processes, reboot your PC or log off. Now you will see a new account "Administrator" which has no password by default. Log in to this account and enjoy the real administrator power of your PC.
2 People Made This Project!
  • Science of Cooking
    Science of Cooking
  • Pocket-Sized Contest
  • Trash to Treasure
    Trash to Treasure
27 Comments
Control Panel > System and Security > Administrative Tools > Computer Management > Local Users and Groups (left pane) > Users (left pane) > Administrator (right pane)
Cant run the cmd. It requires the admin password
What if you can`t run cmd as administrator?? obviously I`m activating it because I`m logged in a user account. It will be redundant if I`m activating an administrator account while I`m already logged in as administrator.
By mistake I deleted some files of Bluestack, after that neighter installing nor uninstalling this app again. I tried to delete through administer account, but didn't work. whenever trying to install it displays blustack is installed already. but its not visible in intalled program in control panel. plz plz help me ;(
when i tried to do this it siad this program is blocked by group policy
i did it and it didn't work at all !!! :(
I first tried the old fashioned way of going to Control panel > User Accounts > Change your account type. Now it is enabling me to click Administrator and the final confirmation "Change account type". But that doesn't seem to be working. That's when I found this page. I tried all three methods, but none of them seem to be working. I just can't seem to figure out why this is happening. Help?
If you get the issue whereby it wont let you run because it needs a password, try the following. It worked for me.
Restart the computer in safe mode with command prompt (via the boot manager, f1 in my case then f8 for options), log into your original admin account (no password needed in this mode) then enter "net user administrator /active:yes".
Now you can restart your pc and it should be there.
Hope this helps anyone that has come to this page with the same issue I have had (corrupt user profile)
