3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
3 Ways to Use El Wire
Fact: El wire makes everything aweseomer.  Here are three different techniques you can use to apply el wire to your stuff and increase your own awesomeness.  All three produce beautiful results, but each does require some amount of patience and time.
While this certainly doesn't represent every method possible, it's a good way to introduce you to some options.  And never forget the power of super glue - you just have to make sure you get it right the first time!
Step 1Materials
Materials
To do these samples, I chose a pattern to use, appropriate colors of el wire in the thinnest gauge, fabric, invisible thread, embroidery thread, and grommets.
El wire from thatscoolwire.com
9 comments
Aug 18, 2010. 3:01 AMantling says:
cool
Jul 31, 2010. 11:59 AMcowscankill says:
I was doing homework when the perfect idea for senior year Halloween costume hit me. Then I saw this :D Oooohhh man, adding elwire to a techno robot costume with surround sound torso would make the idea even better. I better start drawing something before I loose the idea!
Aug 1, 2010. 6:21 AMcowscankill says:
Me neither xD I had to ditch the idea of building a net-book into the torso, but it's still going to have a stereo system built in.
Jul 31, 2010. 4:16 PMred-king says:
when you say "thinnest gauge", is EL wire measured the same as regular wire (higher gauge=thinner)?
Jul 31, 2010. 8:56 AMObediah says:
I had some success with a buttonneer. http://www.buttonfastener.net/ but might be better if i just learn how to work a thread and needle.
Jul 30, 2010. 7:26 PMdchall8 says:
I'm not the most creative person online, so I need more motivation before I feel there is anything awesome about this. First of all I had to look it up. Now I know that EL stands for electroluminescent. That means it glows when you plug it in. I still don't have a good idea where or why I would use it but apparently people put it on pieces of black fabric. Can you give some examples of the use of EL wire so I can share in the feeling of awesome that you feel?
Jul 31, 2010. 8:52 AMACCURATE LED says:
At Disney World in Orlando, there's the coolest application of EL wire that I've seen. On the Winnie the Pooh ride, there's a part where it rains. They use el wire to simulate raindrops splashing on the surface of water. On both sides of the track where the ride moves through the room, there's a horizontal surface painted flat black, with white el wire arranged in concentric rings all over it. The largest ring on this pattern is maybe 6 inches across. The individual rings are on separate circuits, controlled by a sequencer. As the drop hits the surface, the innermost ring lights up, then the next ring, then the next. As each outer ring lights, the one on the inside goes dark- so you have the effect of an expanding circle. There are maybe a hundred of these patterns all over the surface, all expanding at different times. It's very very awesome. Those Disney guys have great ideas!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
3796
Author:scoochmaroo(Click here for more!)
Editor of the Food and Living channels, I believe making things is fundamental to being human! Follow me to see what makes me human.
