3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
3-axis ballhead mini tripod thingie (aka. the tennisball-pod)
I guess the title is pretty self explanatory, but a picture is worth a thousand words!
This is my first instructable so constructive comments are appreciated. I originally posted this on my blog, and after much grudging by my friends to post here, I decided I should. So here goes.
This thing turned out to be surprisingly versatile, and much better to use in practice than I had originally anticipated. The one pictured here gives me about 120 degrees of movement around the two horizontal axes and 360 around the vertical. Not too shabby.
Step 1Materials
Materials
the bill of materials is ridiculously small, and not restricted to these options. You can easily find replacements for all these parts.
You need:
. one tennis ball.
. 1/4' bolt (that fits your camera, be careful to get the right tread. what's it called?)
. a nut, butterfly nut and a washer.
. a tube or can that the tennisball will snugly fit into. Doesn't matter what kind, it should be sturdy. Try using the can that the balls come in.
. some tape and a knife or something.
46 comments
1-40 of 46next »
Apr 17, 2009. 3:58 AMkavinat123 says:
that's cool i will try it . it 's very interesting.
Nov 14, 2008. 2:22 PMthebboy says:
very cool. might try. 5/5
Nov 15, 2008. 4:03 PMHellchild says:
no. dont' "might", Do.
Nov 17, 2008. 2:45 PMHellchild says:
Thanks. if you use just be sure to give me credit.
Nov 15, 2008. 7:07 PMthebboy says:
what? i might.
Nov 17, 2008. 2:44 PMHellchild says:
DO IT!!!
Nov 17, 2008. 3:01 PMthebboy says:
ok, now i just need to find a nut that'll fit my camera.
Nov 21, 2008. 5:27 AMHellchild says:
just take a camera to the hardware store and test different nuts or bolts, that's what I did
Nov 21, 2008. 2:18 PMthebboy says:
ok. do you know how to make it longer?
Nov 22, 2008. 5:50 PMHellchild says:
What do you mean?
Nov 22, 2008. 8:33 PMthebboy says:
the tripod. it's too short, it needs to be a little longer.
Nov 23, 2008. 2:44 PMHellchild says:
I'VE GOT IT!!!! Wrap it in 10 strips bacon, then put in your closet for a week. and when you take it out it will have gotten linger by 2 feet! I tried it, It works!!
Nov 23, 2008. 3:02 PMthebboy says:
really?
Nov 24, 2008. 5:38 AMHellchild says:
yes.
Nov 24, 2008. 2:15 PMthebboy says:
wow, that is crazy.
Nov 24, 2008. 2:25 PMHellchild says:
I know, right?
Nov 24, 2008. 7:30 PMthebboy says:
ya, people say that a lot
Nov 26, 2008. 4:22 PMHellchild says:
what, My Bacon thing?
Nov 27, 2008. 7:41 AMthebboy says:
no, i know right. they say i know right a lot.
Nov 29, 2008. 5:40 PMHellchild says:
Is that bad?
Nov 29, 2008. 5:51 PMthebboy says:
no, but it's starting to get annoying.
Nov 30, 2008. 8:11 AMHellchild says:
deal with it.
Nov 30, 2008. 8:08 PMthebboy says:
ok
Dec 1, 2008. 5:18 PMHellchild says:
good.
Dec 1, 2008. 7:04 PMthebboy says:
uh, now what?
Dec 2, 2008. 11:45 AMHellchild says:
now You Do the fricking bacon thing!!!
Dec 2, 2008. 2:24 PMthebboy says:
oh.
Dec 2, 2008. 3:27 PMHellchild says:
DO IT!!!!!!!!!!!!
Dec 3, 2008. 2:20 PMthebboy says:
uh, thanks for the idea, but i'll try this other idea i have.
Dec 3, 2008. 4:36 PMHellchild says:
what is it?
Dec 4, 2008. 2:30 PMthebboy says:
i'll find a long tube that's tight enough so that it will hold the ball without anything inside the tube, but loose enough so that it can move freely without too much resistence. I can probably find somthing like that.
Dec 4, 2008. 5:00 PMHellchild says:
but then the ball will probably fall through though
Dec 5, 2008. 2:23 PMthebboy says:
maybe. if it doesn't work i can fill it with card board or something.
Dec 5, 2008. 4:46 PMHellchild says:
ok. but, just sayin', that would be a lot of cardboard circles
Dec 6, 2008. 10:21 AMthebboy says:
true, but i think i can find some.
Dec 6, 2008. 10:34 AMHellchild says:
ok then
Dec 6, 2008. 2:30 PMthebboy says:
well, ok.
Nov 23, 2008. 7:26 AMthebboy says:
true.
1-40 of 46next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:SoE
