3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
3-axis ballhead mini tripod thingie (aka. the tennisball-pod)
Step 2Make the ball
Make the ball
using the knife or a corkscrew make a hole in the tennis ball that's large enough to squeeze the head of the nut through. It should best be a tight fit. You could make an X like I did but I don't recommend it, because there is a loss in stability when you do it like this.
Insert the bolt into the hole, put a washer on it and screw it down in place with the nut. Make it as tight as you can. This should securely hold the bolt in place.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:SoE
