Step 3The lower half of the circuits
While the upper halves of the circuits were all centered around the same point, the curves that connect each circuit to the next are all centered around a different point.
- Part 1 is centered around the tip of the 1st half-circle you drew. It stops under the tip of this same first half-circle, and then the wall continues in a straight line in the direction of the "X". The same goes for parts 3 and 4.
- Part 2 is centered around the tip of the 2nd half-circle you drew, opposite to parts 1, 3 and 4 and stops in alignment with its center. The same goes for part 5.
- Part 6 is centered around the tip of part 3 - but trace it only once you're done extending part 3 into alignment with the "X" ! Otherwise, your design'll be off.
Sounds complicated ? Then take your time to re-read the instructions and see how everything fits before going fot the twine and chalk. Once we're done with all the hard work, let's move on to the final steps !
Add Comment
