3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
EASIEST WAY TO MAKE A COMPACT LIGHT!! 3 SIMPLE STEPS!!
What You Will Need -
Tin foil
1 AA battery ( some AAA batteries will work )
1 Mini Lightbulb ( light bulbs used for most flashlights; refer to picture)
Ruler ( if needed )
Step 1Measure Tin Foil
Measure Tin Foil
First, you will need atleast about 4 inches of tin foil.
Try to make it as neat as possible.
It should look like the second image when completed.
8 comments
May 4, 2012. 1:49 PMdoo da do says:
Standard flashlight positive side up touching the bulb.
Apr 19, 2010. 11:56 PMknex_mepalm says:
Do not do this instructable. If the tinfoil touches each other, the battery heats up and...boom. I was tampering once,and i left tinfoil touching each other connected to battery for liek 1 min and boom.
Apr 25, 2010. 7:54 PMknex_mepalm says:
 Yeah, I just did somehting wrong, my foil was way to thin and it melted on the battery.
Feb 19, 2010. 8:03 PMpeepee4 says:
i made a tap light
Aug 14, 2009. 1:56 PMmajjck says:
Good idea on making it more compact. The only reason why mine has two batteries is because it makes the bulb give off more light
Jul 21, 2009. 3:23 PMTimTheScarecrow says:
looks good and slightly simpler than mine. good job
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:vandamfan1234
