3-in-1 Jewellery Organiser From Old Frame
293
Posted in CraftJewelry
Introduction: 3-in-1 Jewellery Organiser From Old Frame
About: Hi, I'm Rachel and I love sewing and making things, especially using old or unwanted materials. My favourite thing to do is upcycle bits and bobs to make pretty new things✂️ Hope you enjoy my instructables!
Do you have lots of jewellery, but don't have a way to organise it? If so, this is the instructable for you! I found that I was rarely wearing my jewellery, beacuse it was all tangled up in a small box, and I would forget about it every day. So I decided to make a jewellery display and organiser from an old frame I had. I wanted a different section for each type of jewellery I own: bracelets, necklaces and earrings, so this organiser is split into three parts. I hope you enjoy this instructable and find it helpful!
Trash to Treasure
This is an entry in the
Trash to Treasure
Step 1: What You Will Need
You will need a good few supplies for this project, but they are all common items and you will have most or all of them at home.
1. An old frame. Choose a size large enough to display all of your jewellery.
2. Acrylic paint(s)
3. Sellotape
4. Scissors
5. Xacto knife and cutting board
6. Ruler
7. Pencil
8. Paintbrush
9. Pushpins
10. Small piece of tulle/ netting
11. Patterned paper
You will also need a glue gun and glue sticks (not shown in image)
Step 2: Remove the Backing
Open up the back of your frame and remove the plastic/glass sheet and the cardboard. Do not discard the cardboard. If there is no cardboard insert, measure the plastic insert and cut a piece the same size out of cardboard.
Step 3: Sort Out Your Jewellery
Take all of your jewellery together and lay it out on the cardboard. Keep in mind that the outer edge of the cardboard will be covered by the frame. Decide where everything is going to go. Roughly make markings to where you would like your three (or more) sections. Remember that you should always mark on the back, and when you turn it around, the sections will be on the opposite side.
Step 4: Measure Out Sections
Place your cardboard into the frame and draw aound the edge where the sides are cut off by the frame. Next, use your markings from the previous step to measure out the sections properly, with a pencil and ruler. Ensure that they are even and straight. Use an Xacto knife, cutting mat and ruler to cut out the section where you want your earrings to go, leaving the thin edge to go under the frame.
Step 5: Cutting the Paper
Take your first piece of patterned paper and lay it under your cardboard. Mark out the paper so that it covers your first section (necklaces for me), with about a 1/2 inch tab to fold under the edges. Also leave a 1/2 inch overlapping onto the next section on the front (see image 4). This will be covered by the next section later.Cut out around your markings using an Xacto knife. Fold the extra paper onto the back and tape into place. Finally, repeat the same method with your second pattered paper, except do not overlap onto the next section on the front. Place your piece into the frame to see how it looks.
Step 6: Attaching the Netting
Cut a small piece of tulle or netting to cover your earrings section, with excess for gluing down. Glue the edges down with a hot glue gun, making sure to pull it as taut as possible. Use small pegs to keep in place until dry.
Step 7: Painting
This step is optional, but I chose to paint my frame in a mint green colour to tie in with the colours in my patterned papers. You can then coat the frame in a layer of mod podge or top coat to seal it, if you have it. For the bracelet holders, I used the inside of a ribbon spool and cut it in half. Use whatever you have, but I would not recommend a toilet roll tube as they are too large and thin. I then painted these in the same colour and cut two cardboard hexagons to glue gun on top, which will stop the bracelets sliding off.
Step 8: Attaching the Push Pins
Now that the other sections are complete, it is time to attach the pushpins for your necklaces to hang from. Measure out the number you would like, evenly accros the top of the section. If you are using round ones like me, push them a small way through, then cover in hot glue on the back. The nacklaces willbe hung from the metal part of the pin. If you are using standard pushpins, you will be hanging the necklace from the plastic part, so push the pin all the way through and cover with hot glue at the back.
Step 9: Adding a Small Box (optional)
Finally, I decided to add a small box at the bottom of the frame to store small pieces from an alphabet necklace I had and other bits and bobs. You could also use this for rings. I used an old box I had and covered the inside in matching paper. You could make a small box out of cardboard yourself, either. I then hot glued it to the bottom of the frame.
Step 10: Organise Your Jewellery!
And you're done! All that's left to do it hang your necklaces from the pins, your bracelets from the spools and your earrings from the netting. Enjoy being organised! Please comment, like and vote for this instructable in competitions if you liked it or found it useful. Share a picture if you made it too!
    • Trash to Treasure
      Trash to Treasure
    • Microcontroller Contest
    • Science of Cooking
      Science of Cooking
    1 Questions
    Very cute idea! How does it stand up? Is there a way of putting the back back on from the frame to stand it up or do u just lean it against something?
    Forgot to add, if you attach the box to the end, it should stand by itself.
    1 more answer
    Hi KariA19,
    Thank you! It really depends on the frame you choose. If it has a stand on the back, you should be able to put the back on and still have a gap for the earrings to hook in. If there is a hook on the back, you could hang this on a wall. My frame had neither of these, so I just leaned it again my wall and it works perfect. Hope that helped.
    Thanks, Rachel.
    2 Comments
    Thanks so much! Please vote for this instructable in the trash to treasure contest and the pro tips contest!
