Step 3Modify the plastic scooter wheel
On another note, you can also use one of the rear wheels thats on one of those childs 12" wheels. (little bikes) The custom pulley I make in the next step will work on either. Something happened to the milled wheel and will let you know what, later down in detail. Note the tire is not one of those knobby tires that are usually found on these push scooters. This tire is a low profile treaded tire that holds more air, and does not sway into turns. The knobby tires are taller and will sway and sometimes pop of the rim under heavy loads and higher speeds. The tires I bought can be found at some high end bicycle stores but only cost about $15. They are called Impac tires 12 1/2 x 1.75 .
Add Comment
