Step 3Fret markers
here is a great online one
http://www.buildyourguitar.com/resources/fretcalc/jscrptclc.htm
while your there check out the whole site its great for do it yourself guitars
be very careful to properly mark the frets then if you want you can cut them in with a fretsaw {i used a hacksaw} and you can fill the shallow cuts with white paint or bits of brass wire or leave them empty like i did
just slappin the bridge on there anywhere without measuring will not work very well.if you have a neck already just measure from the nut to the 12th fret then measure from the 12th fret down the same distance and the bridge must go there,
if your making your neck and the space is limited use an online fret calculater and get the spacings .
you can find one here http://www.buildyourguitar.com/resources/fretcalc/index.htm
enjoy
