Step 6The body
mine is made out of a chunk of mdf {medium density fiberboard} two holes are drilled through the end peice and into the end of the board and is held on either with screws of a screw/bolt used to screw legs on coffee tables and such.
its not terribly strong but it could be reinforced with a dowel between the body and the neck up at the point where it curves back towards the neck.
you might depending on your skill level want to bend some hardwood to make it or just use a bit of plywood scrap{stronger than what i did but uglier}
Add Comment
