30 Minute Micro Waterproof Flashlight
3,096
11
Posted in TechnologyLeds
Introduction: 30 Minute Micro Waterproof Flashlight
About: I like to make stuff and learn through the process. That's pretty much it :)
This is the easiest, simplest way we've found to make a super bright, super mini flashlight using only 4 components, some solder, and a little help from your friendly neighborhood glue gun. And not only that, but if you do a good enough job with the glue gun, the flashlight is waterproof too! So on those rainy nights where you're fumbling with your keys, can't see a foot in front of your face because it's pouring buckets, and your keychain light just went dead because it short circuited, you can pull this little guy out, find your key, and be on your way as fast as you can say lickety split! ...Or as fast as you can say it with a mouthful of water.
This project can actually be completed in about 10 minutes (maybe even less!), but what with taking pictures and all, it took a total of about 20-30 minutes for the flashlight seen here. Also, these things are pretty darn bright, that first picture doesn't do them justice.
Flashlight Contest
Finalist in the
Flashlight Contest
Step 1: Materials
For this project, you'll need:
A 12 volt battery (About as thick as a AAA and about two thirds as long. We bought ours at Home Depot for a little less than a dollar each)
An LED (Whatever color you want! We chose blue for ours)
A resistor (You'll probably need about 100 ohms minimum. Without a resistor, your LED will just fry, and you really don't want that to happen.)
A switch (any kind you want and/or have on hand, we just happen to really like pushbuttons)
Soldering iron and solder
(Optional) Glue gun and extra glue sticks (holds components securely in place and provides waterproofing abilities)
(Also optional) Flux (helps solder bond to materials more readily and easily)
Step 2: Preparing the Battery
To make your life easy, prep the battery first. This can be done by simply scratching the terminals lightly with a pair of scissors, a knife, sandpaper, etc. Anything coarse you have on hand will work just fine. Now add a little flux to the scratched terminal (again, it's optional but highly recommended. batteries are a real pain to solder without flux), and add just a little bit of solder to it. This preliminary solder button will let you make the final joints much more quickly, leaving less time in which you could burn your LED or blow up your battery. Neither of those outcomes are very good.
Step 3: Prepping and Fitting the LED
Now that you have your battery prepped, you need something to solder to it. This is where your LED comes in. Find the positive lead (the longer one) and bend it so that there is a flat spot parallel to the base of the LED (see first pic). Now dry fit it onto your battery to see if it goes where you want it to. Right now's your last chance to change anything before you solder.
Step 4: Soldering the LED, Switch, and Resistor
Ready to solder? Carefully hold the battery (or better yet, make some sort of stand to hold it for you so there's no possibility of slipping and giving yourself a major burn.) and lightly touch the soldering iron to the LED lead. Make sure you don't linger too long or you might burn the LED, making all your hard work go to waste. Same goes for the switch and the resistor. Just be careful and you'll do fine :)
Step 5: Waterproofing!
Now for the best part! This is optional of course, but it really helps secure everything down and makes the flashlight look awesome! (IMHO)
Basically all you have to do is just add glue gun over the whole entire thing. It won't hurt any of the components, and this is your chance to get really creative! Again, be mindful of where your fingers are- this stuff burns really badly. It gets on your fingers and doesn't come off until you've got a great big blister, so please be careful. It really hurts.
So there you have it! We hope you have as much fun making it as we did! :D
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    • Space Challenge
      Space Challenge
    3 Comments
    5mm white LEDs are usually rated at 20 to 30 milliAmps, you are running at about 85 mA. No problem, but it will probably shorten the life of the LED.
    (But I ran one for 24 hours at 100mA, with no apparent change in its characteristics.)
    But these torches may actually only get a total of one hours use per year.
    However, you are wasting a lot of power in the resistor.  Put three LEDs in series with a 68 Ohm resistor on a 12V battery, and you will have about three times the battery life with the same total brightness.
    There must be an Instructable that gives details of the resistor calculation, would someone put a link if they know where one is ?
    last time i checked it isint a very good idea to solder to a battery. It can overheat them causing them to just not work properly or they can pop and shoot battery juice everywhere which isint good at all.
    Good point! I forgot to mention that. However, that's the reason why you prep the battery in the first place. If you don't, you spend even more time with the soldering iron touching the terminal, and the battery getting hotter and hotter. At least this way it's broken up into smaller chunks, and there's time in between steps for the battery to cool off :)
