3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
30-Second Demonstration of the CIR Sand Casting System
video 30-Second Demonstration of the CIR Sand Casting System
In only 50 seconds, the CIR Sand Casting System allows for the replication of a residual limb. This model can then be modified and used to create a final transtibial (below-the-knee) prosthetic socket. The technique eliminates the need for plaster bandages and Plaster-of-Paris, and requires only:
1. A large container
2. Silica sand
3. An air compressor capable of maintaining a vacuum
4. A metal pipe for connecting to vacuum pump
5. Thin plastic bags
6. Rubber bands
The contents of this presentation/publication were developed under a grant from the Department of Education, National Institute on Disability and Rehabilitation Research grant number H133E980031. However, those contents do not necessarily represent the policy of the Department of Education, and you should not assume endorsement by the Federal Government.
23 comments
Sep 12, 2011. 12:07 PMarniethelip says:
I hope this site is still being moderated. It would be great if you could answer my question: If I understand correctly, the final positive cast is made of sand that is being held in shape by vacuum, and that presumably once the vacuum is cut off, the sand would just fall from the mandrel. How then is this cast used to fabricate a lamination? How is the vacuum maintained throughout the process of lay-up, etc.?
Sep 19, 2009. 2:08 PMGrace Robert says:
The Forbes logo has to be displayed for at least 2 seconds, right?
Sep 16, 2009. 5:26 PMnicoluxe says:
I just voted from the link on Facebook. I think this is very clever. Awesome. It seems very simple, almost too simple. Has this actually been used on a person yet?
Aug 19, 2009. 7:02 PMJaycub says:
So this is a prosthetic leg made out of sand?
Aug 17, 2009. 8:25 PMTemplarix47 says:
i dont get it
Aug 13, 2009. 3:46 AM=SMART= says:
what were you casting ????
Aug 13, 2009. 4:58 PM=SMART= says:
Ahhhh ok, i couldnt see what limb it was, I was looking for an arm shape haha
Aug 13, 2009. 11:25 AMmycroftxxx says:
Ahh, brilliant as always. Looking at this in a wider context, is there any way to reasonably integrate this process with your other prosthetic-forming techniques like the heat-gun-and-PET-bottle work done using a plaster positive? It seems obvious that if the thin plastic sheeting were replaced with something more heat-tolerant, a single craftsperson could take an amputee and go from no prosthetic to having the beginnings of a sheath ready for integration into a leg in less than 5 minutes. Assuming that's the goal, what candidates have the required flexibility and thermal tolerance? Now, if you could be so kind as to dump some instructions on the gel-bag prosthetic measuring system and the X-Shape Pylon, I would be _really_ grateful.
Aug 11, 2009. 1:58 PMnlawrence says:
Interesting. I don't know if you know, this technique was developed and patented in the UK somewhere in the late 1970s for prosthetic limbs, exactly as you are doing. They also scanned the good leg and used an NC machine to mill a (left to right inverted) lower limb from wax; then roll molded it in foamed plastic to give a light weight leg that matched the good leg. I am glad to see it still being used.
Aug 11, 2009. 4:58 AMheathbar64 says:
Ok, let me see if I understand this correctly. You seem to be using the vacuum, sealed on top by plastic bag, simply to compress the molding sand around the model. there must be a vacuum hose on the bottom of the bucket somewhere. then it looks like the tube you insert into the middle draws a vacuum to compress more sand into the cavity to form the copy. Is that it? That's really coool!!!
Aug 8, 2009. 10:26 PMred-king says:
could this be used for casting other things?
Aug 10, 2009. 1:33 PMthepelton says:
I recall an old episode of "Mission Impossible" in which the team cast a front grille of a car using sand casting. The whole idea was to convince the people at the border that the guy that owned the car was trying to smuggle a couple kilos of Platinum out of the country disguised as a late sixties car front grille. I don't know if any copies of that episode exist, but it would be worth researching.
Aug 7, 2009. 8:29 AMthecheatscalc says:
Looks like a pretty brilliant process! Although, it's still a bit vague... I'd love to see some more in depth details on how this was done!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
23
Author:CIRnetwork
The Center for International Rehabilitation (CIR) is a not-for-profit organization that works in underserved and conflict-affected regions worldwide to meet the needs of people with disabilities. The ...
more »
