heres a medium-resolution usb microsope i made for under $100 in parts (if you bought them new), had most of this around already and made a new tool :)
parts:
1 radioshack pocket scope
1 white led
1 logitech notebook pro quickcam (zeiss lens)
30 awg wire
heatshrink or black tape
hotglue gun (or whatever appropriate glue your prefer)
(cheap plug) http://www.makenyc.org/
Remove these ads by
Signing UpStep 1Modify the microscope
use your heatshink/tape here to insulate the leads.
test your light with a battery and make note of which lead is the anode/cathode.
on the camera board there is a small (freaking bright) orange led, *carefully* remove it, and wire the leads from our white LED in its place, with this camera the LED is under software control, usb provides all the power. make sure these leads have plenty of slack.
be generous with the hot glue to help act as strain relief on the wires; also be careful positioning the white led so that it points generally where the camera lens points
... internal battery? is it just a lithium poly that wont charge? if so its easy enough to replace the battery yourself, you'll need to check the battery package to verify its a 3.7v "single cell"
digikey/mouser will have a LiPo battery that will fit where the old one did, just be sure that the "mAh" (amp hours) rating matches up so that you get the same battery life.. getting greedy and getting more mAh's may work, or you may get a battery too thick to fit back into the case.
and if you just wanted to hardwire it for webcam use, i would recommend a 3.3v ) regulator fead from the USB +VBUS signal, i should be fine up to ~150mA
.. i know its a rant, but im bored!
www.amazon.com/Wire-Roll-Insulated-Kynar-Blue/dp/B000PDO1B6/ref=sr_1_1
And if i understand, attach the 2 30 AWG wires to each end of the LED, and reroute them to where the orange LED was, and put the wires in place with hotglue?
it all depends on the webcam itself, afiak all logitech webcams work in OSX
