Easy build rifle bipod.
 by mossDboss
Make a bipod in 30 minutes for $3.00
Materials:
1" PVC (or as match to your stock)
.75" PVC
2 bolts
2 nuts (I used nuts with nylon washer)
Electrical Tape
Saw
Cutting Tool
File
*If you shoot yourself that is your problem and you shouldn't have a firearm.
Step 1: Cut the PVC
Cut 2 - 3 inches (5 - 7cm) from the1" (2.5cm) PVC
Next cut a slit down the lenght of the piece
*Warning, cut the slit then place on the stock the if needed widen the slit, about 1/4" was almost too much for my stock
ealbizia says: Nov 3, 2012. 11:51 PM
wonderfull its work...
ilpug says: Mar 27, 2012. 6:11 PM
Wow, nice idea! Works great for lightweight rifles, I'd bet.
lsr1 says: Dec 12, 2011. 10:30 PM
How do you prevent the bolt heads from maring the stock??
mossDboss (author) in reply to lsr1Dec 17, 2011. 11:33 AM
excellent question, something I did not think about (marring the stock). I did not think about this because as it is the pvc cut in the C shape provides enough gap. Padding the C shaped piece would be a good idea.
treesneedtobehugged says: May 9, 2011. 2:38 PM
have you thought about making the pvc camo to better blend in or black?
mossDboss (author) in reply to treesneedtobehuggedMay 10, 2011. 9:26 PM
I did not have paint, this was really just a proof of concept. I tried it out over the week, and it needs a cross bar to make the whole thing look like an "A"
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
