3000 Views Special 5 Tutos in One
Introduction: 3000 Views Special 5 Tutos in One
i have just reached 3000 views (mind blowing).)
Step 1: First the Container
You will need a bottle and a cap both caps should be the same size on the bottle and the cap.
Step 2: Cutting
Take the cap off the bottle then cut in the middle then cut upwards towards the cap
Step 3: Cutting Then Done
Cut up until the spare cap can fit on the bottom push together then walla done.
Step 4: Bow Picture
Youll need paper crayons a pencil and a black marker.
Step 5: Start
Start by making a square with rounded corners
Step 6: Next
Draw curved lines coming from the top two corners do the same thing on the bottom two corners
Step 7: Next
Meet the two lines well not completely curve in the place where the lines dont completely meet
if you get confused just look at the pictures
Step 8: Done
Make the bottom and put the picture in full screen because it is hard to explain.After this outline it with your black marker and then color it with whatever colors of crayons you want.
Step 9: How to Draw Animai
my way
Step 10: Draw
draw a circle
Step 11: Draw
draw the eyes by drawing two circles in the big circle and split it in fouths then color in the bottom left or right
Step 12: Draw
draw the nose by creating a line and add a smaller line to that line on the edge
Step 13: Draw
draw the mouth by creating an upside down triangle then adding teeth
Step 14: Draw
draw whatever hairstyle you want and whatever kind of lashes you wantthen your done.
Step 15: Yarn Fishtail
Step 16: Twisting
twist your yarn into a triangle on a loom of some then add another layer of yarn without twisting and loop the twisted ones over the top
Step 17: Done
continue step 16 til it is the size your wrist is
Step 18: Last But Not Least Yarn Single
Step 19: Next
do the regular rubber band single but with yarn
Step 20: DONE
    • Paper Contest 2018
      Paper Contest 2018
    • Trash to Treasure
      Trash to Treasure
    • Epilog Challenge 9
      Epilog Challenge 9
