30lb Fighting Robot-Nyx
 by MikeNCR
Featured
I recently built a new 30lb fighting robot for the NERC Sportsman class and Dragon*Con Robot Battles events. This instructable will follow the build process and will include links to parts suppliers, machining resources and .dxf drawings of the custom components used to make the robot.
If you are serious about building your own version of this robot, contact me and I'll be happy to help where I can.
Step 1: A pile of parts and the first day of the build
The pile of flat stock was waterjet cut by Westar Mfg. out of 6061 aluminum and 4130 steel.
Drawings for this collection of parts along with materials, thicknesses and quantities can be found here.
The top armor and two supplimental weapons were not included in that collection to allow modifications to be made for weight purposes. Those files are located here.
These drawings were done with the intent that most would be made on a waterjet, and as such did not require dimensioning. Each of the drawings that was meant for waterjet cutting has a 1" reference square on the sheet.
With the great deal of interlocking components, the order of assembly is important. The first components to be assembled are the weapon hub, support hubs and weapon sprocket. Doing this first also showed the first issue in the build. The sprocket model on McMaster.com did not have the correct hole spacing which meant only 3 of the 6 planned bolts would fit. These holes are all meant for a #10 bolt, and without a clearance hole bit on hand, one had to be ordered.
The other main piece of the day was countersinking the holes on the inner rails to ensure there would be no contact between the moving roller chain and the bolt heads. The front threaded spacers also needed to be added and loctited as the bolt heads will be covered by the D shaped bearing blocks during assembly. A product called Nutstrip is used to connect the panels together, allowing for quick assembly.
MikeNCR (author) says: Feb 14, 2012. 11:51 AM
Motorama is this weekend, look for video early next week.
MikeNCR (author) says: Apr 17, 2012. 2:36 PM
I've added a torque limiter to the weapon drive. This seems to have eliminated the shaft snapping issue. Video of the test can be found at:
http://www.youtube.com/watch?v=f9MLRGWG5nE
xXCrazyEyesXx says: Jan 1, 2013. 11:34 PM
Nice :D Im trying to make a battlebot too.. but i must wait to get the receiver & transmitter...
pokemonjarrod says: Dec 14, 2012. 10:04 AM
Can you give me instructions on how to do this robot with a hammer and a saw?
MikeNCR (author) says: Oct 1, 2012. 8:00 AM
Nyx went 6-1 at Dragon*Con Robot Battles and won the 30lb championship. Video is on my youtube channel.
Playlists:
1 and 3lb:
https://www.youtube.com/playlist?list=PL381AC5277547FC6B&feature=view_all
12 and 30lb:
https://www.youtube.com/playlist?list=PLD9E62E0B9714FE3E&feature=view_all
Near Chaos Robotics:
https://www.youtube.com/playlist?list=PLCE1BDB41F8F284AE&feature=view_all
MikeNCR (author) says: Feb 22, 2012. 2:01 PM
Nyx finished with a 2-2 record at Motorama. The video can be found at http://www.youtube.com/playlist?list=PL17C4710E05408188
One loss was due to the motor wires unsoldering themselves. Trims on the radio were turned down to 75% and that functioned as a temporary fix to the issue. The other loss was due to Nyx ending up in a position it couldn't get out of which resulted in a loss by countout.
I'm very happy with performance and I think the addition of a torque limiter to the weapon system will be the final touch the robot needs to start winning tournaments.
DoKToR2006 in reply to MikeNCRFeb 24, 2012. 9:36 AM
Really well done combat bot!
I've seen the videos and i must admit, your robot massive as hell!
Have Nyx suffered serius injuries from the confrontation with Enforcer?
MikeNCR (author) in reply to DoKToR2006Feb 24, 2012. 12:59 PM
Nothing serious, the only damage was cosmetic. It stopped driving because the drive motors got hot enough to unsolder the wires connecting them to the speed controller. I turned the trims down to 75% power and it seems to have fixed the issue for the moment.
rocketman7 says: Feb 11, 2012. 8:02 PM
Great Robot! My friend builds fighting robots too! He is in the Combot competition... He says that you have to hit it with a sledgehammer and drop it off a high building. If it breaks, then it will certainly break in the competition.
graydog111 says: Feb 5, 2012. 5:54 PM
What happened to "Battlebots" on TV? That was one of my favorite shows.
MikeNCR (author) in reply to graydog111Feb 5, 2012. 7:59 PM
They had some issues with advertisers that led to the show being cancelled. They've put on a few non televised events since then, but the main events are now no longer affiliated with Battlebots.
On the west coast, the big group is Combots ( http://combots.net/ )
On the east coast, NERC puts on some of the biggest open events ( http://nerc.us ) and has an event coming up at Motorama in Harrisburg PA in a few weeks.
Robot Battles ( http://www.robotbattles.com/ ) puts on some good events as well in the southeast. Their biggest event is each year at Dragon*Con.
Most events around the US use http://www.buildersdb.com/index.asp to manage registration.
graydog111 in reply to MikeNCRFeb 7, 2012. 11:28 AM
Thanks Mike. I'd love to see them back on the air every week. It would sure beat basketball.
dustinnewton in reply to MikeNCRFeb 6, 2012. 7:57 AM
I always wondered who had control of the episode rights. That's one series that I would gladly buy on DVD in a heartbeat. I always enjoyed watching them.
MikeNCR (author) in reply to dustinnewtonFeb 6, 2012. 8:57 AM
I'm guessing some combination of Comedy Central and Battlebots, which means it probably won't happen any time soon.
Kelpbot says: Feb 2, 2012. 9:30 PM
It seems like a very solid robot! Very nice job. Im not sure about what you want from this robot, but it seems that it has almost more speed than it needs. I would consider using a 1:3 or more gear ratio for the drive system. Although some speed would be sacrificed, the control over turning would increase, and there would be less stress on the motors (although they are very durable). I personally would prefer this to lowering the motor power to slow it down.
MikeNCR (author) in reply to KelpbotFeb 2, 2012. 10:07 PM
With most modern radio systems you can adjust steering sensitivity to make it easier to drive. The high speed allows me to out maneuver the opponent and control the match, or at least that's the idea.
lawsonuw in reply to MikeNCRFeb 5, 2012. 10:25 AM
A better idea is to keep the speed and install a tail-rotor gyro between the receiver and the v-tail mixer. Even the cheapest gyro will let you power-slide around the arena like a god. (works great on ice too :D ) The Holmes Hobbies controllers look like they do synchronous rectification so they're better than the Victor 883's my first bots used, but a gyro is the best.
Also, the side plates holding your wheels look fairly weak. A spinner hit to the corner of the bot and the long spacer bolts will bend right off.
P.S. My most successful bot is Micro Vice http://www.buildersdb.com/botdetails.asp?botid=6135 uses a steering gyro and is a blast to drive.
MikeNCR (author) in reply to lawsonuwFeb 6, 2012. 9:18 AM
A gyro would likely make the bot easier to drive, but I'm pretty happy with the handling as it is.
This bot was built for the NERC sportsman class and Dragon*Con robot battles. Neither event allows high energy spinning weapons, so they're not a major concern for this build.
MV looks pretty good, same with Vice and Insomnia. Planning to take any of them to events again?
lawsonuw in reply to MikeNCRFeb 6, 2012. 10:54 PM
Ah, a no spinner class. In that case you're armor's too heavy :P
No plans to compete right now. While Insomnia had a wicked weapon, it was lightly armored, so it got "retired" in it's last battle. (certainly still competitive with enough spare parts) I botched up the execution of Vice, so it's mostly a sculpture now. Micro Vice was born as a test-bed for a rebuild of Vice, but is FAR more effective than I expected.  I was slowly iterating the design when I got a good idea how to make an AWD motorcycle.  The motorcycle has since chewed up all my time.
P.S. the GWS P-03 was my gyro of choice.  Cheap, fairly symmetrical CW to CCW, and a minimal dead zone.
Kelpbot in reply to MikeNCRFeb 2, 2012. 10:13 PM
Valid point. Just an idea. Good luck with your battles!
thrashermanTotalDIY says: Feb 5, 2012. 2:07 PM
nice! check out my contest for this. Battle bots Contest. Please Enter
frank26080115 says: Feb 2, 2012. 6:28 AM
That's awesome.
How much did this cost?
I saw your other robot, what lessons did you learn from the other robot that you applied to the design of this one?
Do the "nano-tech" batteries really make a difference over traditional Li-poly?
MikeNCR (author) in reply to frank26080115Feb 2, 2012. 8:14 AM
A good portion of the parts were recycled from old projects, but to build this new with all new parts the cost would be around $2000.
I'm trying the nano-tech batteries on this robot and won't know what differences there are besides cost for a bit, as the first event it will attend is in a few weeks.
Giesterfarher in reply to MikeNCRFeb 5, 2012. 7:26 AM
As to batteries. I'm not too familiar with the voltages required for your robots, but for weight savings, you might look into these Shorai Lithium/Iron batteries.
Yes. I said Iron. :)
They have a carbon fiber case, and the one I bought for my Sportster weighed less than 1 lb. and was half the size of my stock battery. The neatest thing about them is, the hotter they get, the more efficient they are, so in an enclosed space with hot motors running right next to it/them, voltage losses should not be an issue.
Good luck with your competition!
http://www.shoraipower.com/c-1-batteries.aspx
MikeNCR (author) in reply to GiesterfarherFeb 5, 2012. 9:46 AM
They don't seem to carry anything in the right size/capacity/voltage combination I'd be looking for.
The current pack is 2.65Ah and provides a nominal 22.2v
Kinnishian in reply to GiesterfarherFeb 5, 2012. 9:01 AM
Hmm, your battery is most likely Lithium Iron Phosphate, also referred to as LiFePO4 and LiPO4. I tried to find more information on the website about the battery type, but couldn't. I am actually very skeptical of battery resellers who don't include more information about their product.
That said, LiPO4 can offer a lot of energy/kg. It's not particularly volumetrically dense, though, and can take as much as 1.5 or 2x the space of bare LiPo packs. Overall, nanotech beats LiPO4 in almost all measures except 1) safety and 2) lifespan.
Anyway. I also wanted to comment in case someone pops up and says "no, you're wrong. Lithium/Fe is _____ type of battery." Because i'd love to hear about something new.
MikeNCR (author) in reply to KinnishianFeb 5, 2012. 9:43 AM
I actually use LiFe batteries in my two other large robots Apollyon and Moros. They're using 5s and 6s A123 systems packs.
As far as I can tell these are just relatively new LiPo's that seem to have decent performance.
Giesterfarher in reply to KinnishianFeb 5, 2012. 9:40 AM
You are correct about them being LiFePO. There is a FAQ section on the site, and there used to be a technical section there as well that was way over my head, but I can't find it now. It's possible it gave away too much and they took it down to protect proprietary secrets?
I'm not familiar with nanotech batteries, but if there is a safety issue, or for that matter a cost issue, then maybe the LFX batteries ARE worth a look. It wouldn't do to have the robot explode when a titanium spike pierces it resulting in mass destruction and death of the audience, would it? ;)
Here's the FAQ section, in case you didn't see it before.
http://www.shoraipower.com/t-faq.aspx
lewisb42 says: Feb 2, 2012. 7:00 AM
Regarding cost, I'd particularly like to know how much the waterjetting was, in case it might just accidentally fit my budget. :)
Also, I like the way you offset the wheels in order to fit the drive chain and sprockets in. That's an great potential solution to a problem I've been mulling over for my next 3-lb robot. (Though I'd be doing it with timing belts, not chain.)
MikeNCR (author) in reply to lewisb42Feb 2, 2012. 8:12 AM
The waterjetting ran $374 + materials and shipping.
dausmus in reply to MikeNCRFeb 5, 2012. 9:34 AM
How does that waterjetting cost compare with laser cutting the same parts?
MikeNCR (author) in reply to dausmusFeb 5, 2012. 9:39 AM
I haven't done any laser parts. I'm a fan of waterjet because you don't get any heat affect zone issues and it can handle a much wider range of materials.
VinceJDJ says: Feb 4, 2012. 4:20 PM
I logged in just to favorite this. Nice work dude!
WYE_Lance says: Feb 3, 2012. 5:41 PM
Wow, way to set the bar high! Good luck in the Make it Real challenge
ad895 says: Feb 2, 2012. 6:00 PM
very cool i like the design. i too build battle bots, but mine is though my school. we have a weight limit of 15 lbs our designs look alot like yours but with a different weapon ours is like a 3-5 pound beater bar
MikeNCR (author) in reply to ad895Feb 3, 2012. 3:20 PM
Nice. I'm a big fan of the BotsIQ/NRL programs. My 12lb bot Apollyon ran in the 15lb college class as Interstellar Overdrive when they did the big event with Battlebots in CA a few years ago. Ended up placing 4th and winning best engineered.
black hole says: Feb 2, 2012. 2:19 PM
Is this named for Nyx, the Greek goddess of the night?
MikeNCR (author) in reply to black holeFeb 2, 2012. 3:15 PM
Yeah, I've been using a general greek theme for names. Some of my other bots are Moros, Kobalos and Apollyon.
black hole in reply to MikeNCRFeb 3, 2012. 2:13 PM
Have you used Enyo (i-nye-oh), the war goddess? It would be fitting.
MikeNCR (author) in reply to black holeFeb 3, 2012. 3:17 PM
Not yet, but it's on the list of potential names.
black hole in reply to black holeFeb 2, 2012. 2:20 PM
Great job, by the way. I voted and I hope you win!
ehudwill says: Feb 3, 2012. 4:29 AM
Good looking robot. Seeing this makes me nostalgic for the days when Battlebots was on television.
Notquitepinoy says: Feb 2, 2012. 6:34 AM
your robot is awesome it has a virtually flat profile... hopefully it fights well... good job
MikeNCR (author) in reply to NotquitepinoyFeb 2, 2012. 2:06 PM
Thanks. It will be competing at Motorama in a few weeks in Harrisburg, PA. I'll be sure to post youtube links once the event's over.
Aron313 in reply to MikeNCRFeb 2, 2012. 2:44 PM
Wow i didnt know there was a competition in PA! I live near coatesville i when is the competition?
MikeNCR (author) in reply to Aron313Feb 2, 2012. 3:14 PM
http://buildersdb.com/eventdetail.asp?eventid=349
150g and 1lb are the 17th, bigger bots are 18th/19th
pchretien says: Feb 2, 2012. 8:17 AM
I don't know much about battle robots but I see a lot of potential in this design for ANY kind of robots. This bot could handle several pounds of sensors, electronic and tools! This is a very clever design. Thanks for sharing.
MikeNCR (author) in reply to pchretienFeb 2, 2012. 9:12 AM
Should easily be able to do that, the current drive system was used regularly for robots weighing 60lbs with the gearboxes in high gear, the current robot weighs 30lbs, so if you put it into low gear it would be able to handle a great deal of extra equipment. The current setup has at least 3/4" of ground clearance, so small obstacles aren't an issue either.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
