Step 5Day 5, wiring and the first test drive
The electrical system consists of the following components:
1 Hobbyking R610 receiver
1 Team Whyachi MS-1 switch (discontinued, MS-05 should be adequate)
1 Turnigy Nano-tech 6s1p 2650mah Lipoly pack
1 Digimix V-tail mixer
3 Holmes Hobbies BR-XL motor controllers
A small pile of deans connectors, wire and bullet plugs
The three BR-XL controllers are velcroed to the baseplate between the three dewalt powerdrive kits. The motor side of the controllers each connects to 1 motor, the positive lead on the battery side runs to the MS-1 switch, which has the positive battery lead connected to the other terminal. The negative lead for each controller connects directly to the negative battery lead. The drive PWM cables connect to the V-tail mixer, which then connects to the Ail/Ele ports on the rx. The weapon controllers PWM cable goes directly to the rudder port on the rx. A power light built using a high output LED and a resistor is connected in the same fashion as the power leads for the motor controllers.
The foam padding that the battery is resting in is to minimize the risk of shock damage in combat.
Once all of the systems were hooked up and calibrated (full calibration instructions come with the BR-XL controllers, only calibrate one at a time to avoid issues) the robot was ready for its first test drive.
Also, the side plates holding your wheels look fairly weak. A spinner hit to the corner of the bot and the long spacer bolts will bend right off.
P.S. My most successful bot is Micro Vice http://www.buildersdb.com/botdetails.asp?botid=6135 uses a steering gyro and is a blast to drive.
This bot was built for the NERC sportsman class and Dragon*Con robot battles. Neither event allows high energy spinning weapons, so they're not a major concern for this build.
MV looks pretty good, same with Vice and Insomnia. Planning to take any of them to events again?
No plans to compete right now. While Insomnia had a wicked weapon, it was lightly armored, so it got "retired" in it's last battle. (certainly still competitive with enough spare parts) I botched up the execution of Vice, so it's mostly a sculpture now. Micro Vice was born as a test-bed for a rebuild of Vice, but is FAR more effective than I expected. I was slowly iterating the design when I got a good idea how to make an AWD motorcycle. The motorcycle has since chewed up all my time.
P.S. the GWS P-03 was my gyro of choice. Cheap, fairly symmetrical CW to CCW, and a minimal dead zone.
