Introduction: 30mm to 40mm Fan Adapter
Picture of 30mm to 40mm Fan Adapter
The noise of the original E3D extruder fan has been driving me nuts. Having worked with MK8 extruders and 40mm fans, I know it doesn't have to be this loud.
Instead of designing some fancy rig that may or may not fit around the heat synch, I decided to create a simple adapter that will all a 40mm fan to be connected to the original E3D fan shroud.
I created the adapter in such a way that screw depth of the original fan (10mm) remained similar (9mm). If you still have them, simply use the 30mm screws to attach the adapter to the original shroud.
To download the entire model go to my GrabCad model
The model was created in Fusion 360 (and re-used the original shroud design from e3d-v6-hotend-3
to simply 3D print the adapter you can download the STL file attached with this instructable.
Materials used in this design if build from scratch:
40mmx40mmx10mm fan: http://amzn.to/2m4eGzp
#4 pan head screw 1/2 inch: http://amzn.to/2F656V5
hex socket m3 15mm: http://amzn.to/2CK0TrP
E3D titan: http://amzn.to/2CPygdR
JAYTEE-Tompkins (author)2018-01-08
Cool, thanks for sharing. Cheers, JAYTEE
Core3D (author)JAYTEE-Tompkins2018-01-08
Thx!
About This Instructable
127views
4favorites
License:
Bio: Avid 3D printer builder, currently completing my 3rd printer design
More by Core3D:Laminated 3D Printer (from Laser Cut Parts Only)30mm to 40mm Fan AdapterLinear Screw Rail
Add instructable to:
