3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
$3.50 DIY TV-B-Gone Micro
Step 20Update: Using a v1.2 Preprogrammed Chip
Due to the requests for preprogrammed chips, I made a modification to the design so that you can use Ladayada's preprogrammed chips with v1.2 firmware. It requires a PNP transistor instead of a NPN, and the way every thing is hooked up is different. I have not tested it, but it should work.
Buy the preprogrammed chip here for $5: http://www.adafruit.com/products/75
The circuit layout will be slightly different than the one for the Instructable.
15 comments
Jan 30, 2012. 6:56 PMacerpeng229 says:
what pnp transistor to use
Mar 6, 2012. 6:32 PMacerpeng229 says:
can it be used in malaysia and all around the world??
Thanks, DARK SPONGE
May 11, 2012. 1:42 PMkill_them_now says:
malaysia eh?nk troll orang ke?hahaha
May 7, 2011. 6:00 PMpac-man says:
Hi so does it actually work because I would like to build one if it does.Nice instructable by the way =).
Dec 25, 2010. 3:43 PMcharchar97 says:
has any1 actually made this?
Mar 14, 2011. 4:50 PMpgraham says:
It doesn't work with the 1.2 pre-programmed chip as drawn. The problem is just in the connection of the switch. positive voltage should go from the battery/capacitor straight to pin 8 (not through the switch), and then pin 1 should be connected to ground through the switch. See the standard v1.2 schematic at http://www.ladyada.net/make/tvbgone/design.html.
Mar 15, 2011. 8:22 AMpgraham says:
Ah, so with your version of the switch you need to hold the button down while it sends the codes, until your target tv turns off, is that right? I will try it again that way with your switch - you're right, it should save battery. I just have it breadboarded for now. I didn't change anything else, though I found it very low power (short range). I added 2 driver NPNs on the LEDs controlled by the PNP as in the official schematic and got much better range, and it doesn't add much bulk.
Dec 25, 2010. 3:54 PMcharchar97 says:
for me it didnt work
Aug 28, 2010. 9:40 AMGibson_SG_95 says:
Great! Thanks for the schematic. Parts from mouser shipped today, and should get here on wednesday. As for the 1.2 chip, i havent recieved a shipping confirmation yet, but im guessing it should get here around the same day. (Both ordered the same day, both shipping via UPS ground) I'll let you know when its finished!
Dec 1, 2010. 4:51 PMcharchar97 says:
hey im thinking of making it. did it ever work. please email me back. i would like to make a small one.
Aug 28, 2010. 4:05 PMsoccer1223335 says:
Hi Gibson, could you take pictures when your finished with yours? I just ordered the 1.2 chip and want to make sure everythings going to be connected to the right spots on the chip. I have a difficult time reading the schematics...
Aug 28, 2010. 4:20 PMGibson_SG_95 says:
Yeah, im going to post some pics of it when its all done. Im no schematic expert either, but im going to pick it apart and figure it out. But yeah, id be glad to help.
Aug 29, 2010. 8:37 PMsoccer1223335 says:
Alright like i just need the schematics turned into words like solder pin x to x. Or pictures of it when your done so i can find out what to soldier parts to :P thanks for the help.
Aug 31, 2010. 2:06 PMGibson_SG_95 says:
Yeah i'll do my best. The pre programmed chip just got here now from adafruit, and the other parts should be arriving tomorrow.
Sep 2, 2010. 7:19 PMsoccer1223335 says:
i just got all my parts. I got the pre programmed chip and all the other parts. Still no clue how to read it though.. let me know how you do!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
70
Author:dark sponge
Hi! I've loved electronics and electricity for as long as I can remember, and electric projects are something I do in my free time for fun. Everything I've learned about electricity is either from exp...
more »
