3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
3.5" HDD Secret Safe
This little project was one that resulted in me not having the right parts.
I was attempting to make a "USB HDD" by shoving a USB Hub and Flash drive together inside a gutted out HDD. But the hub didn't fit... so I was left with an empty shell.
This HDD swings open on a single screw, and can house tons of objects. If you have parts lying around you house, nobody would suspect a thing. You can even close it up, and insert it into a PC drive bay, the PC won't detect it, it will just slide and lock into place, close up your PC case and BAM, you have extra security.
Lets get started.
Step 1Find a suitable HDD
Find a suitable HDD
I used a broken 40gb Maxtor drive I had lying in my parts bin.
Make sure you have the right screw driver for the job.
Mine was held together by 6 torx screws, and one smaller sized torx that was a pain to get out.
Heres what mine looked like before I gutted it:
76 comments
1-40 of 76next »
May 18, 2012. 6:37 PMjimbo-g says:
You could shear the thread off of one of the bolts and use as a drop in pin to hold the cover in place. or maybe carefully remove the thread leaving a few turns at the top of the shank so to open it you can just unscrew with a thumbnail
Mar 28, 2009. 7:43 AMhemmikarl says:
"BE CAREFUL. DO NOT leave them near CRT Monitors, you will completely DESTROY them." That is actually not correct... the magnets magnetise the crt tube and the electron beam deflects due to the incorrect magnetic field in the screen but many screens hava a feature that takes all the charge out of the crt tube and that usually fixes them.
Apr 3, 2012. 12:05 PMcreat0r says:
is that why when magnets rolled against the side of my laptop screen went black? and then it came out normal? :P
Mar 22, 2011. 4:50 PMaj0my0lizard says:
nice save
Dec 9, 2011. 9:05 AMgeckomage says:
If you want some criticism.. here it is. you did a good job :) nice, simple, straight forward, provided all the steps in enough detail that even someone who had no idea what harddrives were could do this project. keep up the good work.
Apr 2, 2009. 9:05 PMjimmyz311 says:
should ad a magnet and a piece of thin steel to the inside top of the lid, so that when turned closed, it stays together better.
Feb 18, 2011. 6:43 PMFurball_Fidelis says:
yea..but i'd be careful if you put your wallet in there if you did that..the magnet might erase your credit and debit cards...
neat instructable though....too bad I don't have any old HDDs to use..
Dec 9, 2011. 9:04 AMgeckomage says:
he removed the magnets <3
Sep 26, 2009. 9:20 PMmithandir says:
And then cut the heads off of the missing screws. Then glue the screw heads onto the top cover over the holes. That way it would not be obvious that screw are missing.
Mar 21, 2011. 10:51 PMZanaji says:
This is awesome :)
Dec 4, 2010. 11:46 AMflame boyyyy says:
ya know if someone breaks in your house then they would see the hdd (asuming it works) and take it....getting a better prize ....Your wallet......lol
Jul 19, 2009. 2:46 PMbuckminsterfullerene says:
You know those magnets you found? Well, im collecting them so eventually i can use them to let me climb up smooth metal surfaces. i have 8 and i need about 20... just one can hold up my entire toolbox and i also need 6 more hard drives
Feb 7, 2010. 1:42 AMFieldownage says:
 You have to post a video of you climbing on metal surfaces when you get to do so...
Mar 14, 2010. 3:42 PMgrue says:
they tried on mythbusters, it failed
Dec 1, 2009. 10:31 PMAndy-K says:
You could just buy a few broken hard drives on e-bay. They always have deals on those, and they are usually pretty cheap. I like the idea though.
Dec 2, 2009. 4:30 PMbuckminsterfullerene says:
oh, yeah, i already bought a bunch of powerful NIB magnets from someplace online. Im currently working on them. They total in 600 lbs of holding force, just enough to safely hold up 150 lbs of human meat. :P   (600/4 = 150)
Dec 9, 2011. 10:58 AMBigMikeDog says:
thats a good idea but the problem is moving them up the wall you would have to pull with 600lbs of forse to get them off un less you used an elactromagnit but i dont know how much they ca hold but its a good idea that you got
Dec 16, 2009. 11:55 AMarduinoe says:
got to your local dodgy computer shop, somewhere small will have boxes of dead hard drives.
Mar 14, 2010. 12:18 PMsleep_deprived says:
You should cut the heads from the remaining screws and glue them in place.  This way when someone looks at the drive, it appears to be completely intact.  Just an idea.
Sep 15, 2009. 5:37 PMjunits15 says:
just a little help, the plates are called platters, and the arm is called the read write head.
Nov 10, 2009. 8:58 PMSupersnail says:
The arm is actually called the actuator arm. The heads reside on the slider at the end of the arm.
Don't know why, but just thinking about it makes me hungry for Corned Beef and Cabbage.
Nov 11, 2009. 5:53 AMjunits15 says:
lol!
Oct 5, 2009. 12:37 AMNykus79 says:
Nice idea... but hard drive is value more than wallet. they could just grab hard drive. Then found your wallet in it
Jul 20, 2009. 8:48 PMsayoian99 says:
I have the SAME exact drive!hmm.
Jul 23, 2009. 10:36 PMnoobererer says:
ME TOO! its not in use but its on the desk right beside me lol
Jul 24, 2009. 11:39 AMsayoian99 says:
mine was in a really bad old Dell which pissed me off a LOT...
Jul 24, 2009. 6:58 PMnoobererer says:
lol nice...i took mine outta of really old pc lol, and Dells really blow...they use like the cheapest parts for the computers and sell them like 3x's as much as it cost to make em
Aug 6, 2009. 10:39 AMfordman15243 says:
I actually have a kickass Dell computer... (yes it has ALOT of ram that I added after i bought it and so on) but it has held up for me very well.
Aug 6, 2009. 4:20 PMnoobererer says:
yea they have some good computers but ive had 2 like 500-700 $ dell computers and they both crapped out on me, and they also werent even very good to begin with
Aug 6, 2009. 6:57 PMfordman15243 says:
ours was around 500 and one gig of ram then we added three more and it worked like a dream, and it's a gaming PC so it has all fast replacements parts, it's awesome!
Aug 6, 2009. 8:22 PMsayoian99 says:
I have a Compaq but it has not really failed me yet...I need more RAM cuz all i have is 1gb w/ just 2 slots...I want at least 2 or 4.....but i dont have the money,and neither do my parents...
Aug 7, 2009. 6:04 PMnoobererer says:
go to newegg and u can buy 2 sticks of ram that is 4gb itself and its like $50-$60 i think...the brand is G-skill and my uncle sometimes uses that and says that its a good brand...heres some links
http://www.newegg.ca/Product/Product.aspx?Item=N82E16820231207
http://www.newegg.ca/Product/Product.aspx?Item=N82E16820231145
and there are many more like that...i find buying online is alot cheaper than in stores :P
Aug 8, 2009. 8:58 AMsayoian99 says:
no,litterally we only have $40 until mom's next payday and dad gets a job.(bad economy pulled him out....)
Aug 8, 2009. 9:57 AMnoobererer says:
ouch...yea my dad also got laid off awhile ago so he was off for like a month then went into steel working
Aug 12, 2009. 4:41 PMsayoian99 says:
well my dad was the one who got laid off and he was the one getting more money...so now,i have a seperation on my hands and never enough EXTRA money....it sucks...
Aug 15, 2009. 3:27 PMsayoian99 says:
i think that's what we're going for,but its hard for him...
Aug 14, 2009. 8:33 AMfordman15243 says:
wow... im sorry.... maybe you can get a part time job or something to help with expenses while your dad searches for a job.
Aug 15, 2009. 3:26 PMsayoian99 says:
he is...
1-40 of 76next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Kingsley721
