3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
36 Volt - 900 Lumen LED Stadium Lights
The end of daylight savings and no lights meant that 5:30 pm soccer practice would be totally dark. With field space severely limited this meant the end of practices.  Next year we will be ready with portable battery powered field lighting, thanks to low cost, high power LEDs and lightweight long lasting lithium 36 volt battery packs from Dewalt.
I built two stadium lights. Placed on opposite sides of the field they do a nice job of lighting a decent size practice area for 10-12 kids. For a larger field or different sport, you may need several more. Each light draws ~.750 Amps, the Dewalt pack is good for 2.3 Amphours or not quite 3 hours. Still more than long enough for practice.
Needed  36 Volt Dewalt Lithium battery pack
These things are great, lightweight, fast charging,  and very convenient after you have followed the directions to add standard power out wires. I will not detail how to disassemble the battery as this is readily available on the internet in several places.
http://www.slkelectronics.com/DeWalt/packs.htm
http://www.youtube.com/watch?v=qQJUEeKo7KQ
9 STAR LEDs (3 watts ~100 lumen each now available direct from China for around $2 per LED, ebay and other sources)
Most  of these high power, high efficiency LEDs operate from 3.5 to 4.0 Volts.  To save money we are not going to use the recommended constant current driver, but wire directly in series. (36 V / 9 LEDs) = 4.0 volts per LED.
CPU style heat sink
1 ohm, 10 watt resister (to add some safety margin)
18 inch long piece of aluminum angle (1/16" by 1 inch)
JB Weld Epoxy
1 inch hose clamp
10' x 1/2 pole (PVC pipe)
Screws, wire, solder
Step 1Solder Leads to the Star LEDs
STAR LEDs are very nice to solder. They have wide solder pads, clearly marked + and -.  Start with the plus side and solder one lead to one + pad.
5 comments
Nov 29, 2009. 6:09 AMrimar2000 says:
Interesting.
Besides portability,
does this device advantages over a low energy lamp connected to the mains?
Nov 29, 2009. 9:16 AMrimar2000 says:
Thanks for the answer.
I forgot to ask something that interests me more: are LEDs more expensive than equivalent  "ordinary" lamps?
Nov 29, 2009. 1:54 PMrimar2000 says:
Thanks for that excellent summary of the situation. In my case, I will follow the mainstream, replacing filament lamps by low power as they get knocked out.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:pobriant
