3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
360 Degree Panning Tripod Mount
video 360 Degree Panning Tripod Mount
360 Degree Panning Time-Lapse Tripod mount is built from a simple kitchen timer,  3/8" long 1/4"-20 bolt, and a matching 1/4"-20 nut. All can be found at your local store for less than $8. First disassemble the kitchen time removing the other white plastic, and timer face plate. Then use a dremel to remove the top post which connected to the timer face plate. This will give you a flush surface to mount your 3/8" 1/4" bolt which will eventually screw into your camera. Glue in place using hot glue or some sort of epoxy for a better hold. Then glue or JB weld on the nut onto the bottom of the metal casing of the timer. This is where your tripod will screw into.
10 comments
Aug 20, 2011. 7:44 PM8H 2D says:
g .. G ... GGGRREEEAAATTT!!!
Jul 15, 2011. 7:02 AMchimericdream says:
This is a great, simple hack. This is the type of thing I love on Instructables. Well done!
Have you tried taking video while using this mount? I would be worried that the ticking from the timer would be distracting. If you've tried it, how noticeable is the ticking?
Aug 9, 2011. 5:17 PMtechy-man says:
It's time lapse video, you'll have no use for audio if the shortest time you can get it to turn for is a few minutes, But if you really want audio you can use a digital voice recorder away from the unit, (Your phone will have one, or put your laptop out of shot with a wire going to the mic) if you want to sync them clap in the beginning of the recording so it is picked up by the camera mic and the recorder put them in editor where you can see the waveforms and look for the clap's spike to align them together and them mute the audio from the mic in the camera and replace it with the new one without the tick tocking, (if your editor allows it you can 'group' the audio with the video so they edit together without going out of sync (I don't know about other ones but sony vegas can do this with the g key when they are both selected. Hope I helped
Jul 24, 2011. 10:27 AMmkunapareddy says:
Cool! I should start making one for myself!
Jul 16, 2011. 5:13 PMnedim155 says:
briliant idea o/
please sign up in eRepublik :)
http://www.erepublik.com/en/referrer/GranoSalis
Jul 15, 2011. 6:56 PMneutral-zap says:
This is brilliant! I've been looking for a way to do this for my time lapse rig. Thank you so much!
Jul 15, 2011. 6:02 AMRaisedByRobots says:
genius
Jul 14, 2011. 2:18 PMzero 8 says:
Thank you.
Jul 14, 2011. 7:54 AMnicholas1951 says:
Very, very clever! Thanks!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
37
Author:JoeMurphy(about me)
Maker of things. Small business builder. Follow my latest project on Twitter @joe_murphy
