360 degree analog camera hat
 by mikeasaurus
Featured
Step 3: Arrange camera array
Next, arrange your cameras around the rim of your bucket ring. The bucket I used had a small ledge which I used to mount my cameras level. Thick cable ties were used to hold each camera firmly in place.
Tighten each cable tie partway, then make any adjustments that are necessary to ensure each camera is equally spaced around the bucket ring, then tighten each cable tie to secure the cameras. Make sure you don't cover the lens with the cable tie.
Set aside the camera and frame assembly for now while the electronics are put together.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
