iImage Information
Hello to all. I wanted to propose to you a simple cellular charger with technology of low level that however works and carries out its task perfectly. Draft of a cellular charge of emergency that can be indispensable if it is found to us with the batteries is down and without a station of charge to hand capacity that is in all those unforeseeable situations that before or after can happen.
Step 1The components
The circuit is much simple one and comprises besides the battery of 9v a made reducer of tension of approximately 2v from 4 diode valves 1n4007, in series to a resistance PTC, member that I have extracted directly from a local p0wer source of cellular from 3,7v that it must have a function to stabilize the tension and to make to limit the current in case too much absorption.
http://www.educypedia.be/electronics/resistorsnon.htm
I don't know much about it. I found at the Interior of the PSU 3 .7V and its value for ohm is approximately 1 ohm.
Thank you for the question , you are interested in the realization of the project?
