This instructable will show you how to make a cool 3D background that goes inside your aquarium and looks like real rock but only weighs less then a couple of pounds.
Step 1: What you need
You will need the following
Tools
Razor or Box knife
Foam cutter or maybe electric knife (both are optional)
Ruler or other sutible straight edge
Marker (sharpie)
Tape measure
Caulking gun
Hot glue gun (optional)
Cheap paint brushes, all sizes
Wire brushes
small buckets
Tarp (optional, to keep mess at a min)
Materials
1 inch pink foam board (the kind you buy at Home Depot or Lowes)
100% Silicone for caulking gun (GE silicone 1 is what some recommend) I used the Red Devil Architectural Grade.  As long as it does not contain any mold or mildew inhibitors and is 100% silicone it should be fine.  The less ingrediants the better IMHO.
hot glue (optional)
Cement or cement overlay
Cement coloring (optional)
Small finishing nails
Note on pink foam: There are two types, one has a plastic cover on it (vapor barrier I think?) and the other does not.  I bought the one that did not have the plastic on it.  If you buy the one with the plastic on it, you will have to peel the plastic off.   Also if you have access or want to buy more foam, you can buy several thickness of the stuff to help create different thick and thin layers.  I just used one sheet of 1 inch stuff and glued it together to get the thickness I wanted.
Note on hot glue:  I have read where some people used hot glue to glue everything together instead of silicone.  It is faster and it shouldn't pose a threat to your fish.  I used a combination of both, hot glue on the smaller pieces and silicone on the larger pieces.  Its up to you.  Trying to get hot glue to come out in the quantity I needed on some of the large pieced didnt work.
Step 2: Lets get started
First figure out if you want to cover just the back wall of your aquarium or more.  Also decide what you want your background to look like.  You tube has some great video of some that others have built and a google search also comes up with some great ideas.  I decided to cover 3/4 of the left side and the entire back wall of mine in a flat stacked stone style.  Some people do 3 sides as well. Use your imagination if your talented enough!
Step 3: Lay the first layer and pieces
Since I decided to do just one side and the back I measured the back first. I wanted the background to come to within 1 inch of the side I was not going to cover, this was because I wanted to taper the edge off and not have a sharp square end showing. I then measure the left side of the aquarium, I decided on this side I was only going to cover about 3/4 of it. Then cut your foam to fit. My 75 gal aquarium was 4 foot long on the back and I needed about 10 inches on the side. I measured 1 inch shorter because of the taper effect or the back piece. I also had to make my background in 2 pieces to get it inside and past the center support when I am finished.  I also cut the pieces 2 inches shorter so that there will be sand under the edge when I  am done. I started with the back corner. I first used the silicone and glued the two corner pieces together along with the first bottom "rock" cut out of the foam.  I used the finishing nails to hold it together until it dried.  Some people cut the rocks first and test stack them.  I just cut them out of the foam as I needed them.  I just used my imagination on the shape of the rocks.  This is where a foam cutter comes in handy.  If you dont want to make one or have one, just use an electric knife or even just a normal knife and cut and carve.  Remember rocks are not perfect but also remember small details will not show up after you coat the thing in cement.
Step 4: Continue to lay pieces...
Continue to cut and lay pieces in the desired pattern you want.  I cut the pieces and test fitted them before gluing them to the back piece.  I glued two pieces of foam together using silicone and the finishing nails for my bottom row and allowed them to dry.  Be sure to remove the nails after they dry.  After they where dry, I carved them to the desired shape.  Use the wire brushed or the razor knife to give them a rough look.  Use your imagination!
Step 5: Building other side
I had to cut mine in half to get it into the aquarium.  I tried to overlap pieces so that the seam would not show but I found this to be too restrictive when I went to test fit it and it would not go together.  I will have to fill in the crack later after its in the aquarium.  I tried to keep all the "rocks" lined up by laying it out on the table while building the other side...
Step 6: Final test fit
After you get all the rocks on it that you want, be sure everything lines up and fits together inside the tank like you want before the next step.  Sorry I did not have a pict of this step but I had one right before I finished it.   Also shows where my other filter will be.
Step 7: 1st Coating
This step is the first in coating your background.  You want to mix the concrete ALMOST water thin.  Sort of like runny pancake batter.  I used a concrete overlay called Ultra Tex U-91-1 but others have used regular concrete and the quickcrete overlay stuff.  What ever you use make sure its doesn't have a lot of stones in it or you will be sorting through it to remove them.  You want a smooth mixture and real watery.  This first coat will only be the base and give the additional coats something to stick to.  You dont have to add color to this coat but I was playing with the color mix to figure out what I wanted for the rest of them.  Once you mix it up just use the cheap throw away brushes and brush it on like paint.  I poured some on then used the brushes to spread it around even.  Dont worry if it looks a little thin, the second and 3rd coats make it thicker and cover what this coat doesnt.  Let this coat dry for at least 24 hrs, more the better
Step 8: 2nd coat
The next coat should be a bit thicker.  About the consistancy of thick pancake batter.  Again spread it on with he brushes.  I suggest adding some of the color you want to this coat. I tinted this coat a lot lighter then the last. Again let this coat dry for at least 24 hours or longer.  The longer you let it dry the stronger it will be.  This coat went on a bit smoother and started filling in the gaps and small details.
Step 9: 3rd Coat
I mixed this coat about the consistancy of the first.  Add the color as well.  I wanted to paint it on using the brush in a dabbing motion.  I didnt want a solid coat because I wanted the last coat with the lighter color to show through. If you want to add more color then mix another batch of cement up with the colors you want and add it to this coat and repeat until you have the color and look you want.
Step 10: Test fit...
After everything is dry, perferably at least 24 hours, I let mine dry a week, test fit it into the tank and try to plan how you are going to get it into the tank with silicone on the back without getting it everywhere.  I cut my spacers and some braces before hand when I realized that the background tried to slightly lean out on the top when it was in place.
Step 11: Clean the tank
I didn t think you needed a picture of how to clean the tank.  Remove the background and make sure the glass surface you are going to stick the background to is clean as you can get it.  I used a razor blade to scrape all scum and hard water stains off mine.  Cleaner the better.
Step 12: Apply the silicone to the back
Next apply the silicone to the back of the background.  Dont be shy about this step and add lots of silicone.  Even though it has cement on it, these things still float like life preservers so dont get skimpy here.  I ran a 1/4 inch bead about every 1/4 to 1/2 inch across.  I dont know if it makes a difference but I ran the silicon lengthwise along the pieces.
Step 13: Install in the tank
Now remember practicing in step 10 ?  Here is where it will pay off.  Install the pieces in the tank and brace/block/tape or hold in place till it sticks.  be sure to press on it slightly to help spread the silicone against the glass.  Allow to dry for at least 48 hours before adding water.
Step 14: Fill, Drain, Fill, Drian, Fill...
This step may or may not be necessary but needs to be considered.  After filling with water, check the PH level.  Let it sit for a day or two and check the PH again.  You may discover that your PH has climbed pretty high.  If it does, drain your tank and refill.  Do this as many times as it take to leach out all the PH raising chemicals.  I did not have to do this step but I included it because other on the net report having to do this.  I dont know if it was just the stuff I used or our well water.  Our well water is high PH to begin with but I let mine sit a week and didnt see any change in PH levels.  I have heard of people having to drain and refill up to 15 times to get the PH to stabilize.  Just check it and decide for yourself, you dont want to kill your fishies...
Step 15: Final fill and add your stuff!
After letting mine sit for a couple of weeks I felt confident to start cycling the tank.  I added my sand, started my filters and started a fishless cycle.  Its way easier on the fish to do a fishless cycle.  I also will be building a canopy to hide the lights and filters, maybe another instructible...
Step 16: After several months of operation
After some requests, I added some photos of the background after it has been up and running for awhile now.  Has some algae growth on it and some black build up, not sure what the black build up is, some sort of algae I suspect, it does come off if I scrub it but I like the way it looks and the fish and trumpet snails dont seem to mind it and it doesnt seem to effect the water quality.  If it ever gets too built up with it I will just scrub it and let it begin again.
1-40 of 76Next »
dafrimpster says: Jun 7, 2013. 1:01 PM
Latex Drylock works much better than concrete. It is durable and it won't raise your PH like the concrete will. You can tint it with concrete tint powder. It is widely used in the hobby and completely safe.
patrick000 says: Apr 17, 2013. 7:00 AM
Thanks i did it. its nice
Klesa says: Jan 3, 2013. 9:24 AM
This is an amazing instructible. I simply love it. I am not this talented and I would like to try it some day.
fatmuemoo says: Feb 23, 2011. 10:34 AM
Hi, I know this post is somewhat dated but I have to questions for ya:
1) How hard is it to keep clean? I know you mention you scrub it occasionally but is that no big deal or does it become an all afternoon event?
2) Do you really have to glue it to the tank? Seems so permanent. Have you ever experimented with other options for keeping it in place?
I love this instructable and i'm thinking about doing it on my 75 gal turtle tank
benkenobi215 in reply to fatmuemooNov 13, 2012. 7:34 PM
hi i just read this and i have an idea, first off let me say that your instructable is frakking fantastic and i WILL be using it with a slightly different design to the rock so that i can make caves for my fish to hid in. however i was thinking that although using silicone is probably the best way to make sure your backround never moves and im guessing it would increase the value of your tank by quite alot. however, using styrofoam gives you options for depth, im sure suctuon cups could be added by carving space for them in the back of the foam. OR and im gonna experiment with this, USE MAGNETS. powerful enough magnets could be attached the to back of the foam using silicone and then with another magnet or flat piece of metal could bue used in the outside of the aquarium to secure in place... thats just the idea i had that would probably make it easier to take out/clean
Rainh2o (author) in reply to fatmuemooFeb 23, 2011. 4:15 PM
I dont really "Scrub" it, i sort of just brush it off occasionally with a stiff paint brush. It only takes about 5 mins of cleaning, like I stated I dont know if you would really have to do this but eventually I would think the algae would build up and look bad otherwise.
Im not sure how you would attach it to the wall any other way except with some sort of suction cup method. I thought about that when I started but with fish, I thought by suction cupping it to the back wall would create a pocket to where fish might get trapped back there. If your turtle was big enough I suppose maybe attaching suction cups to the back of the wall and sticking it to the tank would work.
Another method might be to cut it so it fits the entire height of the back of the tank tightly and then put some large rocks along the bottom, the lip of the tank should hold it down and the rocks at the bottom might hold it in...having it in a turtle tank this way might make it easier to clean because it could be removed. I may have to try this on our turtle tank....
pyroarchist in reply to Rainh2oMar 21, 2011. 1:58 PM
if you glued the pieces together plumb on the back then made it concave like an eighth of an inch on the back and put the suction cups on that you would essentially get rid of the gap in theroy wouldnt you?
JD101 says: Aug 25, 2011. 11:11 PM
Do you think you could use planters foam for this type of project?
david547 in reply to JD101Apr 1, 2012. 8:31 AM
Planters and florist foams would be OK only after full leaching. They contain salts from the manufacturing process. Talk to your local florist and read the instructions for use. I would do water sample tests on the leachate to be sure it is ready for an aquarium. After leaching you can let it dry before starting the manufacturing process.
A. Grower Wholesaler
Pseudocrenilabrus says: Oct 12, 2010. 10:34 AM
Yes, cement leaches out a lot of calcium and raises the pH drastically. Of course, some fish such as African Cichlids like a high pH, but anything over 8.5-9.0 would be too high even for them. Draining and filling is the only way to rid it. DON'T be tempted to use those pH reducers they sell in pet stores. It will only work a short while, then the cement will cause the pH will zoom back up killing everything in your tank. Just a heads up.
dutchthunder in reply to PseudocrenilabrusFeb 3, 2012. 9:09 AM
I've read adding vinegar to the change water helps buffer as well?
Rainh2o (author) in reply to PseudocrenilabrusOct 15, 2010. 5:35 AM
OK..thanks...so far no PH spike...but I have changed the water a couple of times so who knows...the Ultra tex stuff I used is only made of portland and sand and nothing else so I dont know if that helps or not...
winterwindarts in reply to Rainh2oApr 8, 2012. 10:38 PM
Portland is what you have to worry about-it's made from lime.
splitzwit says: Jan 13, 2012. 4:03 AM
excellent work...think i will try something like this....if i can get all the resources together...i am living in ireland and priced one of the ready made 3d backgrounds and would of cost me €185...thats when i found yours...
HubertF says: Nov 30, 2011. 2:56 PM
what did you use for paint/dye to color the last coat of cement?
Rainh2o (author) in reply to HubertFNov 30, 2011. 5:54 PM
I used concrete tinting you can get along side the quickcrete type cement at the hardware store...a very little goes a LONG way
TinkerWorkshop says: Oct 19, 2011. 10:33 AM
What glue would you recommend for gluing the pieces in?
And how heavy was the final product?
My only issue with this scale of a wall is that my tank is probably 1/3 of yours, if not smaller (a square 50 gallon, if I remember correctly). Would you say that the wall would still fit in well?
Rainh2o (author) in reply to TinkerWorkshopOct 19, 2011. 6:40 PM
I started out with silicone but ended up using hot glue for the most of it. You could scale it to what ever size you want or need. I have seen some online (youtube) that take up half the tank...it depends what look you are going for. it only weighed about 3 lbs or so total (total guesstimate)
thats mr sonic to you says: May 28, 2011. 9:38 AM
awesome
juicepig21 says: Feb 12, 2011. 10:35 AM
I am VERY impressed man! I tried to do this with those white grates that cover fluorescent lights and triple-expanding foam.. It was horrible to work with and failed miserably. I really wish I had gone this direction with it. It would have been stronger and (if I was lucky) could have turned out as nice as this one. I would like to see a pic of the populated tank after a little algae growth and such. It must look great.
Rainh2o (author) in reply to juicepig21Feb 12, 2011. 11:36 AM
I just posted some pictures after running this for a long while. Have a coating of algae and stuff on it...I called it aged...LOL...sorry for the cell phone camera photos...hope it give everyone an idea...
nickmccullough says: Feb 2, 2011. 6:13 PM
I am in the process of making a similar project. I am making a basking spot for my bearded dragon(lizard) out of 1/4" plywood, then i am going to use your method of applying concrete to protect my lizard from the glue used in the plywood... Hopefully it comes out looking as nice as yours!
Rainh2o (author) in reply to nickmcculloughFeb 4, 2011. 5:50 AM
Post picts when your done, would like to see it!
nickmccullough in reply to Rainh2oFeb 4, 2011. 9:19 PM
ill do that hopefully, will probably be a week or two tho since i only work on the weekends
Rainh2o (author) in reply to nickmcculloughFeb 5, 2011. 3:45 PM
Mine took a couple of weeks as well, darn work has to get in the way of our hobbies....
nickmccullough in reply to Rainh2oFeb 7, 2011. 4:55 PM
yes exactly, except it is school for me
ihsanadipra says: Dec 25, 2010. 4:41 AM
beatutiful,
i hope can make like this
thanks
keepingstephen says: Oct 19, 2010. 1:16 PM
Looks top notch. Love to see a picture of it with fish and plants added.
makaay says: Oct 17, 2010. 1:59 AM
Hi bro,
one question in my mind. use cement for color that any side effect to fish.reply plzzzzzz.
Rainh2o (author) in reply to makaayOct 17, 2010. 6:52 AM
no side effects seen yet. I have a couple of bluegills in there borowed from the pond. Figured if they do good for s couple of weeks I'll put some topicals in.
Tape-structable says: Oct 7, 2010. 11:19 PM
Looks very professional and real! Very nice job. May I ask what kind of fish you will be putting in?
Rainh2o (author) in reply to Tape-structableOct 8, 2010. 5:11 AM
My son has a medium sized goldfish he has had for 3 years. I am going to move him into this tank and then get some community fish mates, not sure which ones. I originally wanted cichlids but they dont play well with goldfish. I also plan on planting lots of plants and making it a planted tank, if the goldfish cooperate and doesnt dig things up too bad. Since he will be the only one I hope he is occupied by other things.
underwhelmed in reply to Rainh2oOct 8, 2010. 3:48 PM
Really nice background. I've seen similarly constructed backgrounds online before, but yours looks the best.
You can use expanding foam (Great Stuff Brand) in place of hot glue. It is fish safe. Pond builders use it to secure "stones" when making waterfalls in ponds.
With Goldfish you should consider other cool water fish.
I like the high finned Chinese banded sharks (bad name for a great fish IMO) with goldfish, they are very docile and add a different color / shape to the tank.
http://www.csupomona.edu/~jskoga/Aquariums/myxocyprinus/myxocyprinus.html
Another nice cool water fish that do well with goldfish are White Cloud Minnows-
http://www.aquahobby.com/gallery/e_tanictis.php
They are nice fish, visually similar to neon tetras when young and they school quite nicely as well.
Plants will be tuff with goldfish, unless you plant them in pots. Tera cotta work well as do the cheap plastic ones you get from the nursery. A quick coating of Krylon Fusion paint makes them more appealing, and small stones as a top dressing should help disuade the gold fish from digging too badly in the pots.
Plain clay kitty litter makes an excellent aquatic potting soil, BTW.
I would also recommend either Mystery snails or apple snails to help clean the tank. I know some fish keepers aren't fond of snails because they either reproduce in huge numbers or eat all your plants, but these don't eat plants and lay egg clutches above the water line where they can be removed if you don't want babies (they can also be sold on aquatic auction sites like AquaBid.com)
As an aside, perhaps an instructable or explanation of fishless tank cycling would be helpful. I am familiar with cycling an aquarium using straight ammonia and assume this is what you are referring to.
Good luck with your aquarium, it looks good so far.
Rainh2o (author) in reply to underwhelmedOct 8, 2010. 6:21 PM
Thanks for the info. I'm only going to put 1 gold fish in it. I am going to keep the 10 gal he is in now just in case he tears the plants and such out too much I'll throw him back in there. Those sharks are cool!
underwhelmed in reply to Rainh2oOct 8, 2010. 7:40 PM
Well, with tropicals you would have a much broader palette of fish to choose from.
Very nice, well done. I wish I had your artistic abilities.
Rainh2o (author) in reply to underwhelmedOct 8, 2010. 8:44 PM
OK..I reread my last reply...Im not ONLY going to put just the golfish in it...I plan on having other fish as well...the stupid goldfish is only going in there because my wife agreed to the large tank if we got rid of the little tank...since the goldfish is the only thing in the little tank then hes going in the big tank and Im going to go with some tropicals, community type fish as well...I dunno what will happen yet. I may end up putting the goldfish back in the 10 gal tank and sticking it over in the corner of the room. This goldfish is actually getting on my nerves, its limiting my selection of fish!!...LOL...I started out wanting Cichlids but they will eat the goldfish and so will about 75% of all other fish I have seen and like...of course if something eats him, I wont have to worry would I?...LOL...he belongs to my 5 yr old so I cant get rid of him...anyhow believe me if I can do this so can you, I have about .0000001% artistic ability and its in my little finger I dont use...
underwhelmed in reply to Rainh2oOct 8, 2010. 11:52 PM
Well he would be happy in as large a tank as you can provide him, but by heating the tank for tropicals he will become stressed. So, I guess it's a bit of a catch 22.
BTW, I'm a forum member at a fish geek site called aquaboards.com, I posted a link to this instructable in their DIY section. I hope you don't mind. I thought it might bring some people here who might never hear about instructables otherwise.
I keep my goldfish outside in a horse trough, I cut and set it into the front porch / deck. It has been running year round for the last 10 years and the goldfish are all very healthy. Much cheaper and longer lasting than a preformed plastic pond.
Rainh2o (author) in reply to underwhelmedOct 15, 2010. 5:51 AM
The aquaboard word verification you get when you sign up doesnt seem to be working or I am too stupid to make it work. I tried 12 times and gave up.
underwhelmed in reply to Rainh2oOct 15, 2010. 5:47 PM
Sorry about that, the forum changed hosting last week and it has been problematic for people to sign in.
Usually you have to wait for a verification email from the site admin before you can log in. It's sort of tedious, but the owner is trying to keep the forum spamming to a minimum.
You don't have to be a member to read the Forum, AFAIK, only to post or reply.
Here is the link-
http://www.aquaboards.com/showthread.php?72604-DIY-background
Aquaboards and instructables are my must check daily websites, so I was hoping some of those posters might find their way here. It is an older age demo, so maybe not, but stranger things have happened.
Rainh2o (author) in reply to underwhelmedOct 16, 2010. 6:20 AM
Yeah I couldnt even get to the email verification. I was going to sign up. Belong to a number of aquarium boards but not seen that one. I sent a msg to the admin about it.
1-40 of 76Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
