3D Aquarium Background by Rainh2o
Featured
Step 7: 1st Coating
This step is the first in coating your background.  You want to mix the concrete ALMOST water thin.  Sort of like runny pancake batter.  I used a concrete overlay called Ultra Tex U-91-1 but others have used regular concrete and the quickcrete overlay stuff.  What ever you use make sure its doesn't have a lot of stones in it or you will be sorting through it to remove them.  You want a smooth mixture and real watery.  This first coat will only be the base and give the additional coats something to stick to.  You dont have to add color to this coat but I was playing with the color mix to figure out what I wanted for the rest of them.  Once you mix it up just use the cheap throw away brushes and brush it on like paint.  I poured some on then used the brushes to spread it around even.  Dont worry if it looks a little thin, the second and 3rd coats make it thicker and cover what this coat doesnt.  Let this coat dry for at least 24 hrs, more the better
makaay says: Oct 17, 2010. 1:59 AM
Hi bro,
one question in my mind. use cement for color that any side effect to fish.reply plzzzzzz.
Rainh2o (author) says: Oct 17, 2010. 6:52 AM
no side effects seen yet. I have a couple of bluegills in there borowed from the pond. Figured if they do good for s couple of weeks I'll put some topicals in.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
