3D Beaded Purple Heart!!
1,038
23
7
Posted
Introduction: 3D Beaded Purple Heart!!
This Instructable will show you how to make a 3D beaded purple heart
Step 1: Gather Materials
You will need:
1. 75 Beads
  • For this Instructable I'll be using purple beads
  • You can use a different color if you would like
2. String
  • Approximately 3.5/4 Ft.
- Fishing line (6/8 Lb.) works best for 3D projects as it is very strong and thin enough to pass through the beads multiple times
3. Scissors
4.Nail Polish
  • If you don't have any nail polish you can use a permanent marker as well
  • Red works best but any color will do
Step 2: Fold String in Half
1. Cut a piece of string
  • You want to make sure you have enough to finish the project without running out
2. Fold string in half
  • Make sure that both ends are even
3. Paint the left end of the string
  • Paint the string using nail polish or a permanent marker
  • Let it dry for a minute
Step 3: Make Circle #1
1. Put 4 beads on the left end (Painted)
2. Pass the right end (Clear) through the last bead in the opposite direction
3. Hold both ends of the string even
4. Pull tightly to the center
Step 4: Make Circle #2
1. Put 2 beads on the left end (Clear)
2. Put 1 bead on the right end (Painted)
3. Pass the right end (Painted) through the second bead on the left end (Clear) in the opposite direction
Step 5: Make Circle #3
1. Put 2 beads on the left end (Painted)
2. Put 1 bead on the right end (Clear)
3. Pass the right end (Clear) through the second bead on the left end (Painted) in the opposite direction
4. Pull to the center
Step 6: Make Circle #4
Step 7: Make Circle #5
1. Put 3 beads on the left end (Painted)
3. Pull to the center
  • Both ends of the string should now be on the right side
4. Turn the beads to the right so that both ends of the string are on the top
Step 8: Make Circle #6
1. Put 3 beads on the left end (Clear)
2. Pass the right end (Painted) through the last bead in the opposite direction
4. Pass the right end (Clear) into the next bead
Step 9: Make Circle #7
4. Pass the right end (Painted) into the next bead
Step 10: Make Circle #8
Step 11: Make Circle #9
4. Pass the right end (Painted) into the next 2 beads
Step 12: Make Circle #10
1. Put 1 bead on the left end (Clear)
2. Pass the right end (Painted) through the bead in the opposite direction
Step 13: Make Circle #11
Step 14: Make Circle #12
Step 15: Make Circle #13
Step 16: Make Circle #14
  • Both ends of the string should now be on the same side
Step 17: Make Circle #15
Step 18: Make Circle #16
Step 19: Make Circle #17
Step 20: Make Circle #18
Step 21: Make Circle #19
Step 22: Make Circle #20
4. Pass the right end (Clear) into the next 2 beads
Step 23: Make Circle #21
1. Put 1 bead on the left end (Painted)
2. Pass the right end (Clear) through the bead in the opposite direction
Step 24: Make Circle #22
Step 25: Make Circle #23
5. Fold the circle of beads you just added over
6. Pass the right end (Painted) into the next 2 beads
Step 26: Make Circle #24
Step 27: Make Circle #25
Step 28: Make Circle #26
Step 29: Make Circle #27
Step 30: Make Circle #28
Step 31: Make Circle #29
Step 32: Make Circle #30
6. Pass the right end (Clear) into the next 2 beads
Step 33: Make Circle #31
Step 34: Make Circle #32
Step 35: Make Circle #33
2. Let the bead fall to the center
3. Pull the left end (Painted) over to the other side making sure that the bead you just added get pushed underneath the 2 beads that come to an upward point
4. Pass the Painted end into the next bead
  • You should now have 1 string on each side of the project
5. Put 1 bead on the Clear end
6. Pass the Painted end through the bead in the opposite direction
7. Pull to the center
  • Make sure to hold onto the project as you do this because it will move
  • You should now have both ends of the string through the same bead directly in the center of the heart
Step 36: Make Circle #34
1. Pass the Clear end into the next bead to the left
2. Flip the heart over
3. Pass the Painted end into the next bead to the right
4. Put 1 bead on the Painted end
5.Pull the Painted end over to the other side making sure that the bead you just added gets pushed underneath the 2 beads that come to an upward point
  • Now both ends of the string should be on the same side of the heart
6. Taking one side of the string in each hand, tie a knot
  • Make sure to pull as tight as you can without breaking the string
7. Tie one more knot to make sure that it is secure
8. Pass one end of the string into a couple of beads and cut it
9. Set the piece of string you cut off aside
10.Pass the other end of the string into a couple of bead and cut it
11. Set the piece of string you cut off aside
Step 37: Tie Off Loose Beads
1. Take one of the strings you just cut off
2. Pass one end of it into one of the 8 loose beads on the top of the heart
  • You should see 4 loose beads on the top left hand side of the heart and 4 loose beads on the top right hand side of the heart
3. Pass one end of the string into the next 3 loose beads
4. Tie a knot with the other end
5. Tie one more knot to make sure that is is secure
6. Pass one end of the string into a couple of beads and cut it
7. Pass the other end of the string into a couple of beads and cut it
8. Repeat 1-7 for the other side of the heart
    • Trash to Treasure
      Trash to Treasure
    • Spotless Contest
      Spotless Contest
    • Space Challenge
      Space Challenge
    7 Comments
    What kind of string do you use? I have had trouble with the finished piece not being particularly durable when it is handled a lot.
    I don't use string, I use fishing line. 4,6, or 8 pound (Lb) fishing line works best. The fishing line is very strong and flexible and holds 3D pieces such as this one together very nicely and securely. Plus a spool of fishing line can last you a very long time and is relatively cheap. You can also use a thin gauge wire as well, just make sure that it is a strong & flexible wire such as wrapping wire for making bracelets. They do sell beading wire, which is for use with beads, however the beading wire doesn't work very well for 3D projects at all. It's not strong enough to hold the project together properly.
    Thanks. My husband has a lot of fishing line.
    Appreciate all the pictures...that must've taken you a LONG time to do. Thanks for sharing :)
    Thanks, yes it did take a while, your welcome :)
