3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
3D DDR Frame for PS2
Step 10Wire the rest.
Wire the rest.
This looks nasty but is pretty simple, really.
The bottom eight are the eight wires from the controller. I'm not currently using the four from the directional arrow side (up,down,left,right -- the left side on the controller), so those four on the barrier strip on the right are not connected to anything.
The four on the left are from the circle, square, triangle, and cross buttons. You can see they go "out" to the four green wires, which connect to one terminal of the pad switch.
You don't even need the barrier strip if you just wire from the one side of the controller. You could just run the wires directly.
You also see the pigtailed ground wire with the one going out to the blue pigtail in the previous step. Those four wires go to the other side of the pad switch.
This completes the circuit.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
19
Author:impulse94
