Introduction: How to Instantly Fix a Broken Public Restroom Stall Door With 3d Printing
Picture of How to Instantly Fix a Broken Public Restroom Stall Door With 3d Printing
This was my first time designing something from scratch in tinkercad, so I did a basic model of an idea I've had kicking around for a while.  This is a pocket lock and hook combo for use in public bathrooms where the door doesn't quite lock on its own.  Usefull for keeping out zombies! The device simply sits on top of the door, holding it in place against the frame.  The pop-up piston allows a coat or bag to be hooked on, so you don't have to place your things on the floor of the stall.  When not in use, the piston drops back inside the housing, making the assembly fit inside a pocket or purse easily. the entire unit only measures about 1.5 x 1.5 x 2.5" long, and should be able to be printed in one shot. Comments welcome!
jessyratfink (author)2013-07-08
I love this idea, and adding the extra hook for bags makes it extra smart!
Bono_4 (author)jessyratfink2014-11-19
The idea is not bad, but it needs to be improved due to constant bugs with it.
HavocRC (author)2013-07-09
Smart, amazing, and cool. Gave you votes. Good luck!
Bono_4 (author)HavocRC2014-11-19
This product does not work. I have continuously tried to experiment with this product and it has failed multiple times. The product is too brittle and the plastic tends to crack. Although this idea is not a bad one, it needs much improvement! Keep trying and don't give up.
nvan lenh (author)2013-12-19
what software do you use?
waldosan (author)2013-07-08
you are a saint!
About This Instructable
6,729views
29favorites
License:
More by dtuininga:Reclaimed Cable Spool into Cheap Picnic TableHow to instantly fix a broken public restroom stall door with 3d printingHow to make a safe and sturdy Boffer Sword
Add instructable to:
