3D Printable Robotic Actuator
14,012
70
9
Published
Introduction: 3D Printable Robotic Actuator
About: I'm a content creator. I make open source projects and videos for said projects. My goal is to create free and open knowledge for everyone.
Upon research for an upcoming project, I discovered this simple way to make very tiny magnetic actuators. RC enthusiasts have been using these for some time now, but they don't seem very well known. I think there are a lot of useful applications for these little actuators, and they are simple enough to be designed by anyone, which means easy to implement in custom projects. Follow along in the video as I show you how to make the one designed and I will explain how it works. Although I have provided the files to 3D print my design, I encourage you to try and design your own!
Step 1: Watch the Video!
P.s. If you enjoy my content, please consider subscribing to my YouTube Channel!
Step 2: Gather the Parts and Tools
Parts:
  • Magnet (I used this one for my design - McMasterCarr)
  • Metal Rod - 1mm Diameter - I used the leads from a resistor.)
  • Copper Core Wire, at least 30AWG - AdaFruit - or scavenge from old motor or electric clock.
  • Electrical Tape
Tools:
  • 3D Printer, or a service like Shapeways
  • Soldering Iron(if you want to solder the leads on)
  • Snips
  • Tweezers(not essential)
  • Patience (to wind the wire)
Step 3: 3D Print the Parts!
Download the parts from here! - https://www.thingiverse.com/thing:2859499
3D print the parts.
Step 4: Assemble the Body.
Cut some pieces off of your metal rod(resistor in my case) and assemble the piece as shown in the GIF above. The small pieces of rod hold it together.
Step 5: Electrical Tape
Use the electrical tape to cover the holes where you put in the metal rod, this makes sure they won't fall out.
Step 6: Start Coiling the Wire
Attach the wire to the frame and start coiling it around the circular part of it. Keep it going in one direction. The neater and tighter the coil, the better the magnetic field will be for the current that is supplied. Once fully wrapped, strip some of the enamel off of the wire and solder on some pin headers.
Step 7: Test It Out!
I'm testing it by attaching it to a motor driver and microcontroller. This isn't an Instructables on how to do that so I won't go over it(I do cover some of the stuff in some other Instructables). Basically if you put a current though the wires(such as attaching a battery to each side. The coil will generate an electric field. The magnet will oppose that field in some way, and try to spin the actuator arm. This is what gives the movement. If you switch the polarity of the current(battery) it will make the actuator try and go in the other direction. Lots of explanation int he video. Very cool!
Step 8: Design Your Own!
Since these are pretty simple in design, I encourage you to try and make a custom one for your own application. I would love to see what you come up with!
Step 9: Support These Projects!
If you haven't noticed yet, my goal is to bring fun, interesting, educational projects that are available to everyone equally with zero pay walls. However, these projects do cost me both time and money in developing them. If you enjoy these free open source projects, and can spare a few dollars a month, please consider joining my Patreon. Patrons help support future projects, so I can continue to bring more content to everyone!
Sean Hodgins on Patreon
If you want to keep up to date on my projects, subscribe to my YouTube! Watching and sharing my videos is another way to support what I do.
Subscribe to SeanHodgins
And finally, follow me on Twitter and Instagram, where you will find behind the scenes content for future projects. Its also an easy way to ask me questions.
@idlehandsdev on Twitter
@Idlehandsdev on Instagram
    • Water Contest
      Water Contest
    • Clocks Contest
      Clocks Contest
    • Creative Misuse Contest
    9 Discussions
    Nice work , I will try to do one . ( But how many turns you warped )
    I had made an actuator , not as good as this one cause I don't have 3D printer , but it gets the job done. I've posted the instructable.
    The pins that are used in watch links would be perfect for what you used the chopped resistor leads for. And many places, will give them to you for free.
    Nice
    project and presentation. Thanks for sharing.
    I
    visualize a “self actuating” trick toggle switch having the
    actuator made up to look like a bat handle toggle switch.
    Incorporate some sort of proximity sensor into the works. When
    someone's hand approaches the switch, it would “magically”
    toggle, turning something on or off before the fingers can touch the
    switch.
    By
    the way, you can straighten reclaimed motor wire by laying out the
    length with one end clamped to a solid object like a vice for
    example, with the free end chucked into a drill. Put a little
    tension on the wire while running the drill at low speed for a few
    revolutions. The wire will be straight and ready to wind on your
    coil form.
    Great Instructable! I agree with glennlake, better lighting would make your videos better.
    Good idea. I would suggest you use more lighting in your videos.
    You should add a note that the coil MUST be made with enamelled wire. If the wire does not have this insulating enamel coating the coil will short circuit.
    Enamelled wire is also known as magnet wire.
    Thanks for sharing this discovery! I feel like I learned something completely new today! :D
