3D Printed 2 Servo Robot Arm
1,993
24
Posted in TechnologyArduino
Introduction: 3D Printed 2 Servo Robot Arm
About: I am robotics engineer and a teacher whose passion in life is breaking down the maths and academic jargon of programming and robotics into something that everyone can understand, primary school kids include...
This is a very basic robotic system with 2 degrees of freedom (two movable joints). Its two servos can rotate by 180 degrees, just like your elbows and knees. The robotic arm has a capacity to reach any point in its radius and so it can be used to sweep the space around it
Components:
3D printed arm parts: base, mid section and bat (attached here)
Arduino
Servo Shield
2 Metal Gear Servos (I used MG 90)
Rainbow cable
Step 1: Connect Shield and Servos
Place the shield onto the Arduino , it should plug in without any force.
Plug the two servos into the shield mid section (use pins 9 and 10). If necessary use a rainbow cable as an extension chord for one of the servos
Step 2: Plug the 2 Servos Into the Mid-Section
Place the two servos into the slots of the servo holder. You may need to file the slot to make the servo fit!
Step 3: Screw in Servo Bracket
Align the bracket with the slot on the bat and secure with the screw provided (or hot glue if no screw available!) Secure both brackets, one to the base, the other to the bat
Step 4: Secure Base to Table and Upload Code
After you secured the base to the table, you can try uploading some code
The video shows my first try using just a nested loop and one variable (see code below)
#include
Servo servo1; // Define near servo
Servo servo2; // Define far servo
void setup() {
servo1.attach(9); // Set near servo to digital pin 10
servo2.attach(10); // Set far servo to digital pin 9 }
void loop(){ for(int i = 1; i <91; i++){
servo1.write(i);
servo2.write(90-i);
Step 5: Ultrasonic Control!
Upload attached program into the arduino and control the arm through the Ultrasonic Sensor
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    Really cool! Thanks for sharing!
