3D Printed Actual Speaker
Introduction: 3D Printed Actual Speaker
Hi all,
This project is done for the purpose of testing and without calculation, and yes; it worked!
Watch the video to see it in action, and to see how it works.
STL files:
Step 1: How It's Done..
After printing the two parts (no support, 0.2mm layer hight), use a thin coiling wire and make a coil on the printed cylinder ( I used 0.35mm wire with 120 turns), the thinner the wire and the more turns the better results. Remember You need to mach the power and resistance of your audio output or you might damage your sound card/sound system!
For the test, use a cheap speaker with 3.5mm jack output or a cheap amplifier so you don't damage something expensive ;)
In the hole of the base, I used a 2.5cm stack of magnets (size 1mm X 5mm).
Happy testing!
    • Science of Cooking
      Science of Cooking
    • Trash to Treasure
      Trash to Treasure
    • Pro Tips Challenge
      Pro Tips Challenge
    Way to go!
    For your next experiment in speakers, try a single light (i.e. 1mm height) magnet mounted on the membrane and a coil with more vindings at the "bottom" (that will keep the wires from influencing the sound by physical tugging the membrane).
    A small LM386 amplifier (0.5W max.) would be good for such experiments :)
    Getting back to you tomorrow on the piezo - following the links you send me (and then some) made the needed brain click :D
    Have a nice day (err night :)
    Sorry, I didn't get a notification for your comment!
    Thanks for your advice my friend I'll try that, and thanks for the help with the other stuff master!
