3D Printed Back to the Future TIme Circuit Clock
14,612
178
20
Published
Introduction: 3D Printed Back to the Future TIme Circuit Clock
The front left LED .stl file was incorrect and has been updated. The time circuit clock will display the following via the LED displays.
Destination Time – (Top-Red)
The destination time is an area that shows a fixed date and time. Use this area to display an important date in your life such as wedding, Birthday or the date you first discovered this most excellent clock.
Present Time – (Middle-Green)
The present time is the current date and time. You set this initially when you download the Arduino and you can adjust the hour and minute via the RGB LCD display keypad.
Last Time Departed – (Bottom-Yellow)
The last time departed will alternate between three different important dates every 20 seconds. Use this for birthdays, the date you finished building the clock, the day you met your significant other, etc.
The time circuit clock will announce the time between the hours of 8:00 AM and 9:30 PM. The time is generated via the Music Maker MP3 shield. The audio files for the time announcement were recorded by my wife and are included. To enhance the clock further, I enlisted a voice impersonator that recorded the time announcements as "Doc Browns: voice. Contact information for the voice impersonator is included in this “Instructable”.
Power on message and time announce files are provided. You can change these by simply by recording new .mp3 files and putting them on the music maker board micro SD card.
The clock is 3D printed and utilizes (1) Arduino Uno, (1) Music Maker MP3 shield, (1) ChronoDot real time clock, (1) RGB LCD keypad, (9) 3 mm LEDs, (1) voltage isolator and a few other components. A complete parts list is provided at the end of this “Instructable”.
The .stl files for printing the clock parts, Arduino code, wiring diagram, decal template and the audio files are located here. The clock was printed on a Lulzbot mini which has a print bed size of 150 mm x 150 mm. Due to the smaller print bed, some parts require gluing.
The entire clock was printed with HIPS filament with the exception of the pushbutton extensions that were printed with black ABS filament.
Step 1: Components - Arduino Uno R3 Controller
The Clock is controlled by an Arduino microcontroller. The Arduino handles the interface to (9) four digit LED displays, (6) AM/PM LEDs, (1) MP3 Music Maker Shield, (1) RGB LCD pushbutton display and a Chronodot real time clock.
Step 2: Components - Arduino Proto Screwshield
Step 3: Components - ChronoDot Real Time Clock
Step 4: Components - Music Maker MP3 Shield
Step 5: Components - Audio Speakers
Step 6: Components - LED Displays
Step 7: Components - LED Backpack
Step 8: Components - SN74HC138N 3 – 8 Line Decoder
Step 9: Components - RGB LCD Shield
Step 10: Components - AM / PM LEDs
Step 11: Components - Power Supply
Step 12: Components - Panel Mount 2.1 MM DC Barrel Jack
Step 13: Components - LM7805 Voltage Stabilizer
Step 14: Components - Perma-Proto Breadboard
Step 15: Components - Filament
Step 16: Components - Wire
Step 17: Components - Paint
Step 18: Components - Screws / Washers
Step 19: Clock Decals / Design
Step 20: 3D Printing - BTTF_Pushbuttons.stl
Step 21: 3D Printing - BTTF_Pushbuttons.stl
Step 22: 3D Printing - BTTF_Top_Left_LCD.stl & BTTF_Top_Right.stl
Step 23: 3D Printing - BTTF_Front_Side_Left.stl & BTTF_Front_Side_Right.stl
Step 24: 3D Printing - BTTF_Speaker_Covers.stl
Step 25: 3D Printing - BTTF_Front_LED_Left.stl & BTTF_Front_LED_Right.stl
Step 26: 3D Printing - BTTF_Bottom_Left.stl & BTTF_Bottom_Right.stl
Step 27: 3D Printing - BTTF_Back_Left.stl & BTTF_Back_Right.stl
Step 28: 3D Printing - Assembly View 1 & Assembly View 2
Step 29: 3D Printing - Assembly View 3 & Assembly View 4
Step 30: 3D Printing - Assembly View 5
Step 31: 3D Printing - Assembly View 6 & Assembly View 7
Step 32: Construction - Glue the Top, Front and Bottom Halves
Step 33: Construction - Glue the Front Halves
Step 34: Construction - Glue the Top Halves
Step 35: Construction - Glue the Back Halves
Step 36: Construction - Glue the Bottom Halves
Step 37: Construction - Drill Guide Holes for LED Displays / Drill / Expand LED Mounting Holes
Step 38: Construction - Drill Guide Holes for RGB LCD Display
Step 39: Construction - Drill / Expand RGB LCD Pushbutton / Contrast Holes
Step 40: Construction - Layout the Left and Right Sides
Step 41: Construction - Insert the Speaker Covers and Speakers
Step 42: Construction - Glue the Enclosure
Step 43: Construction - Assemble the Enclosure
Step 44: Construction - Assemble the Enclosure
Step 45: Construction - Prepare the Enclosure for Painting
Step 46: Construction - Prepare the Enclosure for Painting
Step 47: Construction - Paint Enclosure
Step 48: Construction - Paint Enclosure
Step 49: Construction - Assemble Music Maker
Step 50: Construction - Wire and Mount the 4 Digit LED Displays
Step 51: Construction - Wire and Mount AM/PM LEDs
Step 52: Construction - Mount the Voltage Stabilizer
Step 53: Construction - Mount the Arduino Uno
Step 54: Construction - Mount the RGB LCD Display
Step 55: Construction - Wiring Diagram
Step 56: Construction - Wire the Perma-Proto Board
Step 57: Construction - Wire the Screwshield & Install Arduino
Step 58: Construction - Install Music Maker on Screwshield
Step 59: Construction - Mount /Wire DC Barrel Connector
Step 60: Construction - Install Decals
Step 61: Construction - Install Decals
Step 62: Construction - Attach Base / Bumpers
Step 63: Construction - Make Power Connection
Step 64: RGB LCD Operation
Step 65: RGB LCD Operation - Hour Increment / Decrement
Step 66: RGB LCD Operation - Minute Increment / Decrement
Step 67: RGB LCD Operation - Backlight & Contrast
Step 68: Time Displays
Step 69: Time Announcement
Step 70: Power Up Sequence
Step 71: Parts Listing
ADAFRUIT
Arduino Uno R3 - Adafruit.com Product ID: 50
Adafruit "Music Maker" MP3 Shield for Arduino w/3W Stereo Amp - Adafruit.com Product ID: 1788
ChronoDot Real Time Clock - Adafruit.com Product ID: 255
Stereo Enclosed Speaker Set - 3W 4 Ohm - Adafruit.com Product ID: 1669
SD/MicroSD Memory Card (4 GB SDHC) - Adafruit.com Product ID: 102
Perma-Proto Half Sized Breadboard - Adafruit.com Product ID: 1609
AMAZON
Blinggasm Waterslide Decal Paper 10 Sheets Pack, Clear or White, Inkjet or Laser Printer Choose From Menu (WHITE FOR LASER PRINTER) - Amazon.com
http://www.amazon.com/gp/product/B00ZLVF670?psc=1&redirect=true&ref_=oh_aui_search_detailpage
OMNIHIL AC/DC 9V 2A High Quality Power Adapter - Amazon.com
http://www.amazon.com/gp/product/B00CAC399U?psc=1...
SMAKN® L7805 LM7805 3-Terminal Voltage Stabilizer 5V Voltage Stabilizer Power Module - Amazon.com
http://www.amazon.com/gp/product/B00RKY0NP6?psc=1...
Arduino Proto Screw Shield - Amazon.com
http://www.amazon.com/gp/product/B00HBVVKPA?psc=1...
Lowes
Paint - Rustoleum Forged Pewter
Screws - #2 x 3/8” and #4 x ½ “
Lulzbot.com
Gray Hips Filament - Lulzbot.com Gray HIPS 3mm, 1kg, filament (ESUN)
Black ABS Filament - Lulzbot.com Black ABS 3mm, 1kg, filament
Glue (SCIGRIP Weld-On 3 Cement)
Tapplastics.com
Glue (SCIGRIP Weld-On 3 Cement) - Tapplastics.com
http://www.tapplastics.com/product/repair_product...
Glue Applicators - Tapplastics.com
Autozone
Bondo Glazing Putty
Back to the Future Contest
Second Prize in the
    • Oil Contest
      Oil Contest
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    20 Comments
    Great build, Not sure how i missed this when the BTTF comp was on. Ive been wanting to build one of these for ages. Just looking at your 3d files and it seem like the front led left and right are of the same file.(both files have 2 columns of LEDs) Are you able to take a look and reupload the correct one?
    Wired up the LCD as per diagram and the backlight slightly lit but only a faint blue and no text but had squares filling the display on top row only and the bottom was blank, purchased another adafruit 714 but the same happened, tried the rgb example on its own and hello world and a number appeared which counted in seconds,put the BTTF sketch back on the board which compiles ok back on the Arduino uno and again, back light, no text, defiantly wired up as shown and as for multiple definition issue i never had one, downloaded the librarys and continued as administrator and clicked replace all for any duplicate files, i still have the complete working set of library's should any one need them. but i am stuck on the above comment if anyone can help
    If the clock circuit is not wired up and working the display will probably not show anything. The backlight on / off button may work but not 100% positive. Make sure you have the real time clock circuit working correctly. I am pretty sure that is your problem since the demo program from Adafruit works.
    Just curious, what did you have to do to avoid multiple definition issue?
    also, i used ide 1.56-r2 beta
    i got the library folders and examples and went through arduino ide verify it and sorting out the errors 1 by 1 and some files needed renaming to the the ones stated as errors then i removed robot control and it worked, for some reason, robot control file was making the sketch error each time until removed
    No problem, the only difference is the display is blue and not rgb do you cannot select a color
    It was before version 1.6.9. Search google for "Arduino first defined here" and you see several potential solutiuons.
    which arduino version did you use as i have all the librarys and examples but keep geeting this
    C:\Program Files (x86)\Arduino\libraries\Adafruit_LED_Backpack/Adafruit_RGBLCDShield.cpp:54: multiple definition of `Adafruit_RGBLCDShield::rightToLeft()'
    Adafruit RGB LCD Shield Library\Adafruit_RGBLCDShield.cpp.o:C:\Program Files (x86)\Arduino\libraries\Adafruit_RGBLCDShield/Adafruit_RGBLCDShield.cpp:54: first defined here
    Adafruit LED Backpack Library\Adafruit_RGBLCDShield.cpp.o: In function `Adafruit_RGBLCDShield::Adafruit_RGBLCDShield()':
    C:\Program Files (x86)\Arduino\libraries\Adafruit_LED_Backpack/Adafruit_RGBLCDShield.cpp:54: multiple definition of `Adafruit_RGBLCDShield::autoscroll()'
    C:\Program Files (x86)\Arduino\libraries\Adafruit_LED_Backpack/Adafruit_RGBLCDShield.cpp:54: multiple definition of `Adafruit_RGBLCDShield::noAutoscroll()'
    C:\Program Files (x86)\Arduino\libraries\Adafruit_LED_Backpack/Adafruit_RGBLCDShield.cpp:54: multiple definition of `Adafruit_RGBLCDShield::createChar(unsigned char, unsigned char*)'
    C:\Program Files (x86)\Arduino\libraries\Adafruit_LED_Backpack/Adafruit_RGBLCDShield.cpp:54: multiple definition of `Adafruit_RGBLCDShield::readButtons()'
    collect2.exe: error: ld returned 1 exit status
    Error compiling.
    i have tried 3 different IDE versions with different results
    thanks
    I updated the STL files and uploaded the files so they sit flat since a user was having an issue.
    Very, Very, VERY impressive! Wow - a great job and excellent instructions!
    One suggestion to help make it even more 'authentic' would be to use Dymo labels like the original in the movie, instead of printing decals.
    Again, a super job!
    Thanks fro the link!. I thought Dymo's were extinct. Only $9.20 on Amazon and $6.59 for labels and I am all set. The decals are kind of a pain and this would make things more authentic so I just placed my order for the Dymo.
    Great job man! Thanks a lot for sharing it ... my daughter will love it!
    I appreciate the feedback. Be sure to breadboard the circuit as much as you can before you do the final assembly. I created the electrical schematic / designed on the fly as I built the clock (not a recommended practice) I do not think there are any typos in the schematic but if there are, it is easy to correct things in the breadboard stage.
    Awesome: Great detail, great pictures, well-done! Thanks for sharing!
    Thanks for checking it out!
    Very impressive. Thanks for sharing. Some day I'll make it ;)
    Thanks for the feedback!
