3D Printed Case for Transistor Tester
Published
Introduction: 3D Printed Case for Transistor Tester
I've buyed a tester for mosfet and transistor. This is a simple tester that scan the piece connected on the three contact, and show on lcd the type and the scheme of electronic component. This good accessories don't have a case. I've designed and printed this case.
Step 1: Download the Stl File and Print
The first step is download the stl file and print it. If you don't have a 3D print, you can use the 3DHubs service. After this step is important add the connector to the 5 pins of connections. This step is necessary because the case is most high to use the simple connectors. See the photo.
Step 2: Make a Hole and Assembly
The last step is make a hole on the case where are the button of tester. If the button is more down, you can use a screw to connect the button to the case, or a swab of cotton buds.
Now you can assembly all together, and you can test it!
    • Woodworking Contest
      Woodworking Contest
    • Planter Challenge
      Planter Challenge
    • Make it Move Contest
    2 Comments
    I just mount mine to scraps of hardboard with stand offs. Done, and done.
