This Instructable is going to guide you through the critical steps to create a CAD file for 3D Printing a Cryptex. It will use Autodesk Inventor 2012, and will detail the critical steps needed to create it. Basic experience with your CAD software of choice is recommended. This should include creating parts, assemblies, extruding, cut extruding, revolving, embossing, and basic parametric modeling skills. If you are interested in making an exact copy of my Cryptex, please skip to Step 17, which details modifying my files to edit the combination.
IF YOU ARE CURRENTLY SEARCHING FOR, OR PLANNING ON SEARCHING FOR, THE GEOCACHE CRYPTECH (GC3K7QE); YOU SHOULD BE FOREWARNED THAT THERE ARE SPOILERS INCLUDED IN THIS INSTRUCTABLE.
Remove these ads by
Signing UpStep 1: Dimensions
> Number of Letters in your combination (I used 6)
>Outside radius of the rings (This dimension is not critical, I just used it as a reference point. This dimension gives a target point for all of the other ones.) This will give you an approximation of how large your cryptex will be.
For my cryptex, I wanted a fairly large cryptex, with easy to grip dials, easy to read letters, and an easy to access compartment. I wanted it large enough to fit into your palm, but not small enough to fit easily into a pocket.
Visit Our Store »
Go Pro Today »
thanks
I have a list of about 20 patents that I want to get patented, but because I am a poor college student, I have nowhere the amount of money I need to get a patent...
To print out this model, I used a Stratasys uPrint system, with a .01" layer resolution. It took 26 hours to print the dials, another 6 to print the inner chamber, and then about 24 hours of soaking to remove the support material.
If you wished, I could upload the stl, but you would be stuck with a cryptex that had the combination "cipher", and the words "Geocache" and "Cryptech" engraved on the side.
Thanks! I had planned on doing something like this for a while.
I am now working on a version for myself that I can adjust the combo on. This will take me a while, because the mechanical complexity is higher, and the tolerances will be smaller.
Nice Job!
When the part is finished, you dump in in a bath, which dissolves the material away from the part, and frees up the rings.
If you go into this field, bring it with you on interviews for internships. It's impressive.
