3D Printed Cue Stick Chalking Tool
1,595
4
5
Published
Introduction: 3D Printed Cue Stick Chalking Tool
About: I am a novice cad designer and I own a modified cube 3, modified r1+, and a modified SD4. I design things in tinkercad and fusion 360. I also am into programming and most recently arduino. More projects comi...
I designed and 3D printed a handheld motorized tool that chalks cue sticks.
Step 1: Supplies I Used
Step 2: Tools I Used
  • 3D printer
  • Soldering iron
  • Hot glue gun
  • Fusion 360
Step 3: Design
I started by designing the case in Fusion 360
  • I put holes in the case for the wires, button, battery, and motor.
  • I designed a button making a cylinder then filleting the top outside
  • cut a square hole in that to clip into the button
  • made a spinner with thin walls that bend and slightly wider top allowing a tight fit on the chalk
  • added hole for 9 volt clip
Step 4: Assembling
I put everything inside the case. Glued clip into case. Soldered wires from the battery to the button to the motor.
Step 5: Coming Soon
here is a rendering of a smaller,faster,and stronger version of the cue chalker
    • Clocks Contest
      Clocks Contest
    • Oil Contest
      Oil Contest
    • Make it Move Contest
    5 Comments
    Cool. I want to make a little disk that goes in the basket of a pool table, and when a ball lands on it, it turns a light on. That way, when it is over, you know where to go to get the balls.
