Introduction: 3D Printed Custom Rollerblades
This instructable will walk you through creating custom skates made just for you! Through the magic of 3D printing you can make ones shaped perfectly for your feet. Not only that, but they are lighter than normal rollerblades (The pair of printed skates is lighter than my one normal skate which weighs 3lbs) and also more portable. They can be clipped with a carabiner to a backpack and with a quick lacing method using 'S' hooks they can be put on or taken off in 30 seconds. In the video I am riding one printed rollerblade and one regular, this is because I hadn't printed a second one yet but it gives a nice side by side comparison. The printed rollerblade was surprisingly strong, I didn't have to 'baby' it while skating and I ride on one leg a couple times in the video to show how stable it is.
I'd also like to address some common concerns: I went with a 3 wheel design because I wanted the bottom part that held the wheels to be a single, solid piece and a piece for three wheels was the largest I could print on a Makerbot Replicator 2. As for comfort I used some craft foam and packing foam in the boot and on the footplate and between it and my normal skate I couldn't tell a difference. I didn't include a 'brake' on the skate because of size constraints (a separate piece could definitely be added) and I've never used them as I feel toe dragging is a better stopping method.
To make this project you will need access to a 3D printer, or a company like Shapeways, as well as some general CAD knowledge for the program you will use (the tutorials they offer should be plenty). For these instructions I am using Autodesk Inventor 2013. Also make sure to wear the appropriate safety gear and use caution when testing! Most importantly, have fun and be creative!
Updates: Since building I have made a seconds skate and found that the toe part of the boot and the tongue are essentially only for looks so I updated my design without those and just added a little toe guard to the end of the boot for safety. All the files will still be on the thingiverse page.
The files for all parts can be found on Thingiverse HERE.
Step 1: Parts List
For this project I did all the 3D printing on a Makerbot Replicator 2 but any printer with approx 11" x 6" x 5" build volume will work. You can always crop my drawings and scale them as needed.
Non 3D Printed Parts:
6 x 8mm or 5/16inch diameter bolts and corresponding nuts (2.5 to 3 inches in length)
6 x 3mm or 1/8 inch diameter bolts and corresponding nuts (around 1 inch in length)
6 x Rollerblade wheels (anything that uses standard bearings and has an 8cm diameter or less will work)
12 x Standard rollerblade bearings (these probably will come with the wheels)
2 x Shoelaces (string also works in a pinch)
A plethora of washers or other spacers (I've added a file on Thingiverse for 3D printed spacers that are the perfect size for the skates)
Some type of foam or styrofoam padding.
(Optional) 6x 'S' hooks for quick release lacing.
Tools:
Screwdriver
Crescent Wrench
Tools:
Screwdriver
Crescent Wrench
Step 2: Designing the Bottom Skate
The most essential part for this project is the 'bottom' part of the rollerblade. This part is where you add the wheels, bearings, axles, and spacers to make it roll! Since this part will be the same for everyone there is no real need to make your own (unless you want to of course!) and you can just use the STL from my file. This is where you will mount your custom boot. You can see on the sides I included slits for extra straps if needed and a hole on one end so they can be clipped to a carabiner for portability.
All files can be found HERE.
Step 3: The 'Boot'
I have included files for the complete skate boot (as well as it broken down into two pieces for easy printing) and the tongue. After reading the next few steps on designing your own boot if you feel it may be too complex, you can always try scaling my design to be the appropriate size for your foot rather than completely redesigning your own. As a reference I am a shoe size 9 (US mens). If you do this all you will have to do on CAD is Step 7 of this 'ible entitled 'Designing Mount Holes', as scaling will throw off the mounting holes I have already drawn in the design. Get ready to make your custom boot!
After testing the design I have found that the heel part of the boot is essential for good control, while the toe part mostly is there for protection. Keep this in mind, if looking just for functionality you could first try just printing the heel part and add the toe on at another time. The tongue also doesn't add much besides protection as well and so isn't completely necessary.
Step 4: Making the Custom Footplate
Now on to the coolest aspect of the project, the custom 'boot' part of the skate! To design one for your own foot you will first have to get a paper and a writing utensil and trace your foot (I traced my shoe but I really recommend doing your foot). When tracing angle the pen out to get a slightly wider drawing than your actual foot. Also try and put your weight onto the foot you are tracing so it is the exact size it will be when you are standing on it.
From this drawing you are going to make a simple sketch by drawing three circles on the outline of your foot: one at the heel, the middle of the foot, and the ball of your foot. Measure and record the diameters of each circle. You can see this in my drawing. Next draw a line between the centers of the circles and from the center of the last circle to the tip of your foot. Measure and mark these as well. Now open your CAD program and create a new drawing of the circles and lines that space them apart. To connect the circles use the 'arc' or 'curve' tool and draw lines following the shape of your foot and connect the circles together and create the curve towards your toes. You can see sketch of this for reference (ignore the little rectangular drawings on the side of mine). Once you are satisfied click 'Finish Sketch' and then click the 'Extrude' tool. Select the sketch you just made and make sure all parts of your foot drawing are selected. In the 'Distance' box enter 0.2 inches and click 'OK'. You now have a custom footplate! Feel free to make it more detailed than this, this was just the easiest way to describe the process. If you want to make it specific to your right or left foot change the curves a little bit and go for it!
Step 5: Designing the Sides of the Rollerblade
This is definitely the most complex step of this 'ible, but the complexity is all up to your ability and creativity. There are basically two ways to design the boot:
1. (EASY/LESS CUSTOM WAY) Make a new sketch on the top of the footplate and do the exact same drawing you did to make your footplate with the three circles and curves, but this time make the circles all 0.3 inches smaller in diameter. This allows for 0.15 inch walls on either side of your foot. Once you have this sketch extrude the thin section between the outside of your sketch and the outline of the footplate. Make it whatever height you want. It won't have very good hold on your feet but will be easy to do.
2. (HARD/COMPLETELY CUSTOM WAY) You will use the 'Loft' tool which essentially blends sketches together. To take advantage of this you will create a series of planes all parallel and spaced about an inch apart. You can do this by clicking the arrow under the 'Plane' button (circled in red in the pictures) and selecting 'Offset From Plane', select a plane parallel to the one you want to make and enter how many inches the new plane should be from the plane it is spaced from. On each plane you will make a drawing of what you want the boot outline to be at that height. I can't really help you with this since everyone has different feet and ankles. My advice is to get paper and use a caliper to take measurements and draw out a rough sketch before designing that layer on the computer. Then once you have drawn as many of these layers as you desire click 'Loft', select all the drawings, and click 'OK'. You now have a custom boot. You can see each of these steps in the picture. In my pictures you can see me lofting the upper part of my boot, but for the lower toe guard it follows the same steps, just uses different drawings.
Step 6: Adding Shoe Lace Holes
To cut holes for your shoe lace you are first going to need to find the plane that cuts your shoe lengthwise, so it's the same on either side. Do this the same way we found the plane for the footplate and use it to make a new offset plane. This offset plane should be a few inches away from the original plane so it doesn't intersect the boot at all. Make a new sketch on this plane and draw circles (diameter 0.2 inches) for where you would like to place holes for your laces. Make sure to add some holes at by the toe to secure your tongue to the skate later. Extrude these circles through both sides of the skate. Use my pictures for reference.
Step 7: Designing Mount Holes
Now to mount the boot to the bottom part of the rollerblade we will have to add some mount holes. The dimensions for them can be seen in the picture (ignore the silly footplate they are drawn on). There are two lines spaced one inch apart with three holes in each line (diameter of the holes is 0.14 inches). The spacing between each hole is three inches. Draw a sketch of this on the top of your custom footplate, click 'Finish Sketch' and use the 'Extrude' tool again to cut them out of the footplate.
This would also be a good time to cut out some material from the footplate to make the prints take less time and save plastic. Draw closed shapes and extrude them in the same fashion as the mounting holes. If you go back to Step 3 you can see how I've cut spaces into my design.
Step 8: Extras
To make your design unique you can add some cut outs along the back or by the toe. To do this use the technique of offset planes and then extruding the patterns you sketch to cut the shapes out of the boot. For mine I just used an arrow pattern on the heel and the toe as well as the tongue. Make it cool!
Step 9: Splitting the Design for Printing
This step is optional if your printer has a large enough print volume to make the boot in one piece. If not you will need to decide on a good place to split it. I chose to split it right after the second set of mount holes. To do this you will need to create a new sketch on the plane that you would like to split your boot on. Next draw a a large rectangle (or circle) that if viewed from the front, with the toe of the boot pointing at you, will completely enclose the boot. Click 'Finish Sketch' and extrude the shape to the side of the boot you want to remove. Make sure in the extrusion menu you select the option to delete material rather than create a new solid shape (check tutorials for your CAD program to figure out how to do this). You now have a section of the boot that you can print!
Step 10: The Tongue
Now it is time to make the tongue for the skate! I have included my tongue file and a blank tongue file for you to create your own design on. The only thing that should be left the same are the two holes in the blank tongue so it can be mounted to the skate. Feel free to change anything else!
Step 11: Print
This step will be different for each kind of printer so I won't go into too much detail here. After you have all your part files, you may have to save a copy of them as STL files (or whatever file type your printer needs). Be sure to properly scale and place your design to be printed. None of the pieces require supports or a raft so now need to do those. For printing the boot and tongue I used the lowest resolution (for speed) with 1 shell, a 10% fill, and 0.3mm layer height. The boot takes about 7 hours to print depending on the size; the tongue is about 45 minutes. These settings were wonderful as the boot was strong but allowed a little flex for comfort and a better fit. For the bottom part of the skate I printed it on the lowest resolution using two layers and a 15% fill with a layer height of 0.3mm (I had the raft and support settings off). These settings worked extremely well and although it did take a laborious 6.5 hours to print it came out super strong!
Step 12: Assembly
To attach the Boot parts onto the bottom part of the rollerblade grab the smaller bolts and nuts (3mm or 1/8inch) and line up the mounting holes of the boot with the bottom part of the skate. Slip the bolts through these holes and secure them with the nuts (the head of the bolts should be on the side by the boot, so the nuts will be connected under the bottom part of the rollerblade).
Now, take all 6 bearings and place one in each side of the wheel in the circular cut-outs for them. Then grab the bottom parts of the rollerblade and your 6 larger bolts and nuts (8mm or 5/16inch). Feed one through each of the three holes on the bottom skate, the holes are drawn to a size that the bolts will need a crescent wrench to screw them into the part. If you want them to just slide through you can drill the holes out a bit. Once the screw is through one wall of the bottom part of the skate, slide on washers (or printed spacers), a wheel, and then more washers (or another printed spacer) in this order. You should have the wheel spaced right in the center by washers on both sides (you can see this in my pics). Then screw the bolt through the hole in the other wall and tighten the nut enough that it holds in place but doesn't stop the rollerblade wheel from spinning. Repeat this for each of the three holes on the first rollerblade, and then for the second. Your rollin'!
Step 13: Lacing and Padding
To lace up your skates grab the longest shoestring you can find! Place the tongue inside the skate and near the toe of the boot there should be some holes in the tongue, start the string going under the tongue before putting it through the skate and criss-crossing up the sides of the skate. This secures the tongue in place. Continue to criss-cross the string to the desired top hole and you are done!
Alternately if you have S hooks (see pictures) you can use these and instead of criss-cross lacing just feed one side of the string up each side of the skate and place an S hook on the string between each hole on one side. The you can hook the laces together for a much faster way to get in and out of the skates. See pictures for clearer example.
The plastic is pretty uncomfortable in just a sock so it is a great idea to add some padding into the skate. I used regular foam and craft foam sheets. Cut out one piece using the template you drew for you foot and lay it on the bottom of the boot, you can use some glue to make it stick if desired, but mine fit snugly (you could also try a shoe insert). I also used a piece cut out to the shape of my heel and wrapped it inside the boot. This piece did require some glue. I added a little bit of thicker foam at the ankle and was set to go! After the foam it's quite comfortable and I had no pain while skating.
