3D Printed Glow Star
1,233
20
4
Published
Introduction: 3D Printed Glow Star
Hi,
this is my first instructables hope you guys like it.
Please give some feedback on how you thought i presented. It's been real fun working on this project and hope to see your twist on this design
Thanks for looking
SCRUMPY JACK
Step 1: Bill of Material "BITS AND BOBS"
THINGS YOU WILL NEED
  • 3D Printer
  • Sharp snap knife
  • Loctite superglue
  • Clear silicone
  • Silicone gun
  • 100m Glow in the dark filament
PRICES & LINKS
snap knife = http://www.ebay.co.uk/itm/Silverline-9mm-Zinc-Allo...
Superglue = http://www.ebay.co.uk/itm/Loctite-Mini-Trio-/12181...
Clear silicone = http://www.ebay.co.uk/itm/GENERAL-PURPOSE-SILICONE...
Silicone gun = http://www.ebay.co.uk/itm/Cox-Silicone-Sealant-App...
Glow filament = http://www.ebay.co.uk/itm/3D-Printer-Filament-ABS-...
IF YOU GO TO YOUR LOCAL £ SHOP YOU SHOULD FIND ITS A LOT CHEAPER
you may find that most of the materials you will need you already have. Apart from the glow filament i already had most of the items !! so it cost me £10.90
Step 2: 3D Printing & STL Files
I used CURA during the slicing process i find it better than other slicing software (personal preference)
STAR JIG
Download this file http://www.thingiverse.com/thing:1212514
PRINTER SETTINGS
  • 0.2 mm layer height
  • 100% fill density
  • 60 (mm/s) print speed
  • 220(c) hot end temperature
  • 40(c) bed temperature
This is the jig I used for the star segment gluing #EasierLIFE
STAR SEGMENTS
Download this file http://www.thingiverse.com/thing:1211656
  • 100% fill density
So you need to print this out 11 times this will give you your 55 segments !!!
****TOP TIP****
(ONCE PRINTED LEAVE BED TO COOL DOWN BEFORE PEELING AWAY) ANTI-WARPING)
Step 3: Cleaning, Gluing & Jigging !!!
OK if your one with your 3D printer you may find the next step will be easier for you than it was for me.
Since the cold weathers has come in, me and my printer haven't been seen eye to eye !!!!
  • With your knife clean all edges make sure there is no blobs on the corners
  • Apply superglue along one of the long edges ( NOT THE BOTTOM EDGE )
  • grab one more segment and place in the Jig holding the glued side to the new segment (HOLD UNTIL DRY)
  • Keep adding segments to the Jig until the shape is made
Rinse and repeat until you have 11 sections like you seen in the pic
Step 4: Setting Up & More GLUING !!!
  • SO place 5 of your newly made segments together and apply glue wait for 10 minutes then apply more !!!
  • Repeat again so you have 2 large halves
  • interlock the 2 large halves together and apply more glue
  • leave to dry for 15 minutes
Step 5: Last Segment & Sealing Up
  • Add you last segment to the top of the star then glue in place (wait for 5 minutes)
  • your star might have gaps where the segments have joined so apply a thin amount of clear silicone. i would advise you ask for help to hold the star as its very light in weight. depending on you brand of silicone leave to dry for a minimum of 10 hrs
Step 6: PRINTING FIXTURES. Adding Fixture !!
Print the blocks these will hold the light fixture in place
Download this file http://www.thingiverse.com/thing:1217545
  • 0.2 layer height
  • 100% fill density
  • 10 (mm/s) print speed
LAST STEP !!
  • Loose fit block onto light fixture as seen in pic
  • Apply glue to blocks, sick them to the top as shown in the pic
  • once dry the light fixture should pivot back and forth this will allow easy access to the bulb.
  • Fit around rose of the light bulb and your done
hope you guys enjoyed this this was real fun to make. My son loves the light he now calls it "the magic light"
Please vote guys and give us a like on Thingiverse http://www.thingiverse.com/scrumpy0jack/designs
Thanks Again
SCRUMPY JACK
    • Creative Misuse Contest
    • Water Contest
      Water Contest
    • Oil Contest
      Oil Contest
    4 Discussions
    kd7eir
    2 years ago
    The blocks file does not exist on Thingiverse. Do you have another link for them?
    Very nice!
    This would make a great Christmas tree topper. Just hang it from the ceiling above the tree.
