3D Printed Handlebar Caps
 by MakerDrake
There always comes a time when one of these little buggers falls off, and then begins the annoying process of unwinding grip tape on a road bike. With a handy 3D printer and Autodesk Inventor, this problem is an easy fix. If you are to do this at TechShop like I did, it's even easier.
The class needed for this project is the 3D Printing SBU and then of course you need a membership. If you wish, TechShop also has  Autodesk Classes for members to get you started in the software!
Step 1: Measure the handlebars
Using a digital caliper, I measured the inside diameter of the circle to use for reference in the autodesk sketch. What I got was .77in for the interior diameter. This is really the main bit that is needed for design. I also measured the thickness of the metal itself to give a good reference of the total size since I didn't have existing caps to work with.
amandaghassaei says: Oct 1, 2012. 11:48 AM
very cool! did you have to do any test with the press fit, or did it work the first time?
MakerDrake (author) in reply to amandaghassaeiOct 20, 2012. 10:19 AM
It fit perfectly when I installed it, but the cap end was a bit small so for this design that I documented I increased the diameter. As long as the measurements are accurate I wouldn't be worried!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
